Tip & How-To about Computers & Internet
CHANGE INTERNET EXPLORER TITLE
1. start ->run-> gpedit.msc
2. choose User Configuration, Windows Settings, Internet Explorer Maintainance, Browser User Interface, and doubleclick Browser Title.
3. Activate Customize Title Bars, and type something in there. Doesn't matter what. Let's type: QWERTY. Click Okay.
4. Fire up Reg editor. (start, run, regedit)
5. goto HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main.
6. Look for the key: Window Title. There you'll find the value: Microsoft Internet Explorer provided bt QWERTY.
7. Change this key to anythig you like and exit regedit.
8. Fire up IE and look at the titlebar
WinXP security: If you don't do steps 1 to 3, you won't find the Window Title key
Computers & Internet Logo
How do I Delete "suggested sites"
The easiest way to get rid of that "Suggested Sites"button is to use group policy or if you know where the key is located in the registry, you can turn it off. But I'd suggest to just use group policy and this is how:
- Go to start run (windows key + R) and type in gpedit.msc
- Local Computer Policy --> User Configuration --> Administrative Templates --> Windows Components --> Internet Explorer
- Look for and double click "Turn on Suggested Sites" (it's not configured by default, which explains why it keeps coming back)
- Click the "Disable" radio button --> Apply --> Ok
Done! Hope it helps... Peace!
Aug 13, 2014 | Computers & Internet
How do i turn off inprivate browsing
Hello angel_a_38,
You can simply close all in-private browser windows. When you launch the Internet Explorer application it should be in normal browsing mode.
Hope this helps! Please give 4 thumbs up if it does!
Jul 06, 2011 | Microsoft Internet Explorer 8
how to enable control panael,taskmanager
Method 1 - Using the Group Policy Editor in Windows XP Professional
  1. Click Start, Run, type gpedit.msc and click OK.
  2. Under User Configuration, Click on the plus (+) next to Administrative Templates
  3. Click on the plus (+) next tSystem, then click on Ctrl+Alt+Delete Options
  4. Find Remove Task Manager in the right-hand pane and double click on it
  5. Choose the option "Not Configured" and click Ok.
  6. Close the Group Policy Window
Method 2: Change the Task Manager Option through the Run line
  1. Click on Start, Run and type the following command exactly and press Enter
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Policies\System /v DisableTaskMgr /t REG_DWORD /d 0 /f
Method 3: Change Task Manager through a Registry REG file
  1. Click on Start, Run, and type Notepad and press Enter
  2. Copy and paste the information between the dotted lines into Notepad and save it to your desktop as taskmanager.reg
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
3. Double click on the taskmanager.reg file to enter the information into the Windows registry
Method 4: Delete the restriction in the registry manually
  1. Click on Start, Run, and type REGEDIT and press Enter
  2. Navigate to the following branch
    HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies\ System
  3. In the right pane, find and delete the value named DisableTaskMgr
  4. Close the registry editor
For Control Panel
Start | Run | Type: gpedit.msc | OK |
Navigate to >>>
User Configuration\Administrative Templates\Control Panel\
Prohibit access to the Control Panel
[[Disables all Control Panel programs.]]
Jan 12, 2010 | Microsoft Windows XP Home Edition
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
In my pc my task manager is no working longer, so how can i fix it, and uses it again.
Verify that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
Task Manager in the Local Group Policy
1. Go to "Start" -> "Run" -> Type "Gpedit.msc" and press on "Enter" button.
2. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
3. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
4. Close "Gpedit.msc" MMC.
5. Go to "Start" -> "Run" -> Type "gpupdate /force" and press on "Enter" button.
For the "Domain Group Policy" Verify correct registry settings::
1. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
2. Navigate to the following registry keys and verity that following settings set to default:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DisableCAD"=dword:00000000
3. Reboot the computer.
Jun 06, 2009 | Microsoft Computers & Internet
165 people viewed this tip
David Payne
David Payne
