Tip & How-To about Computers & Internet
Multiple G-talks
MULTIPLE GOOGLE TALK IS POSSIBLE BY RUNNING THE GTALK WITH A SWITHCH CALLED /nomutex
THE FOLLOWING IS THE PROCEDURE FOR PUTTING THE SWITHCH TO THE SHORTCUT ICON:-
To edit existing Google Talk shortcut:
1)Right click on the Google Talk shortcut.
2)On the right click contextual menu, click on Properties.
3)Go to Shortcut tab on Google Talk Properties window.
4)On the Target textbox, add in the /nomutex to the end of the line so that it looks like below (or you can simply copy and paste the below syntax and replace the original).
"c:\program files\google\google talk\googletalk.exe" /nomutex
5)Click on OK.
To create a new shortcut for Google Talk:
1)Right-click on the desktop or anywhere you want to place the GTalk shortcut.
2)Select New on the right click context menu.
3)Then select Shortcut.
4)Copy and paste the following line to the text box when prompted to type the location of the item:
5)Click on Next.
6)Give the shortcut a proper name such as Google Talk or Google Talk Multiple or Google Talk Polygamy.
7)Click OK until you are done
Computers & Internet Logo
cannot connect to google talk service error 1
Is it your network blocking you from accessing Gtalk? Try web messenger like KarooLark web Gtalk http://karoolark.com/#gtalk
Jun 29, 2011 | Google Talk
Gtalk Connection Error
Check your internet connection active or not. If it is active, then do the necessary settings in your GTalk application allowing your application to connect.
Nov 12, 2008 | Google Talk
Gtalk Error 1
that's a problem with software...
try downloading google talk again and install it... even then if you are getting the same problem... its a problem in the Operating system... some file must have corrupted... so re-install OS and install gtalk...
or simple way.. juz login to your gmail id... u have an internal gtalk available... in inbox itself.. hahaha..
Sep 17, 2008 | Google Talk
How2use webcam (it works) for online talking via google-talk
As you are using to talk with your son on webcam, I can understand how Important it is to use Webcam in Gtalk.
But unfortunately Google didn'r include the webcam option as of now in Gtalk.
I am sure they will add this feature with the next comming versions of Gtalk.
Aug 04, 2008 | HP Pavilion dv6000z Notebook
202 people viewed this tip
David Payne
David Payne
