Tip & How-To about Computers & Internet
Yahoomessenger
Multiple yahoomessenger
1. Go to Start ----> Run . Type regedit, then enter .
2.Navigate to HKEY_CURRENT_USER --------> Software --->yahoo ----->pager---->Test 3.On the right pane , right-click and choose new Dword value . 4.Rename it as Plural. 5.Double click and assign a decimal value of 1.
That's it done!! Now close registry and restart yahoo messenger .For signing in with new id open another messenger
Computers & Internet Logo
multi yahoomessenger
Just follow the steps:
  • Go to START->RUN-> Type ‘regedit’ and press ENTER.
  • Then navigate to ‘HKEY_CURRENT_USER\Software\Yahoo\Pager\Test’
  • Now in the right pane right click New->DOWRD Value. Name it as ‘Plural’.
  • Now Double click the the Plural DWORD you created & set the value to 1
Hope that helps you. Good luck!
May 29, 2010 | Yahoo Messenger
system restore has been turned off by group policy
1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
Nov 24, 2009 | HP Pavilion dv1000 Notebook
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
In the right-pane:
---> System
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
In my pc my task manager is no working longer, so how can i fix it, and uses it again.
Verify that the "Local Group Policy" or "Domain Group Policy" doesn’t block you from using
Task Manager in the Local Group Policy
1. Go to "Start" -> "Run" -> Type "Gpedit.msc" and press on "Enter" button.
2. Navigate to "User Configuration" -> "Administrative Templates" -> "System" -> "Ctrl+Alt+Del Options"
3. In the right side of the screen verity that "Remove Task Manager"" option set to "Disable" or "Not Configured".
4. Close "Gpedit.msc" MMC.
5. Go to "Start" -> "Run" -> Type "gpupdate /force" and press on "Enter" button.
For the "Domain Group Policy" Verify correct registry settings::
1. Go to "Start" -> "Run" -> Write "regedit" and press on "Enter" button.
2. Navigate to the following registry keys and verity that following settings set to default:
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Policies\System]
"DisableTaskMgr"=dword:00000000
[HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Group Policy Objects\LocalUser\Software\Microsoft\Windows\CurrentVersion\Policies\System]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\policies\system\]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DisableCAD"=dword:00000000
3. Reboot the computer.
Jun 06, 2009 | Microsoft Computers & Internet
background image cannot be changed
i had a similar problem...
go to Start > Run
type "regedit" hit enter
go to:
HKEY-CURRENT-USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies \ System
see if there is a key that has a name, something like: NoBackground, or something like that... if so it should have a number 1, change it to 0, and that should be it...
tell me how it went :)
Jan 12, 2009 | ScriptLogic Desktop Authority
170 people viewed this tip
David Payne
David Payne
