Tip & How-To about Computers & Internet
INTERNET BANDWIDTH
TO INCREASE INTERNET BANDWIDTH...
just Click Start then Run and type "gpedit.msc" without quotes.
This opens the group policy editor. Then go to:
Local Computer Policy
then Computer Configuration
then Administrative Templates then Network then QOS Packet Scheduler
and then to Limit Reservable Bandwidth.
Double click on Limit Reservable bandwidth. It will say it is not configured,
but the truth is under the 'Explain' tab i.e."By default, the Packet
Scheduler limits the system to 20 percent of the bandwidth of a
connection, but you can use this setting to override the default."
So the trick is to ENABLE reservable bandwidth, then set it to ZERO.
This will allow the system to reserve nothing, rather than the default 20%
Computers & Internet Logo
how do I adjust my computer bandwith.
here try this steps to increase the computer's bandwidth upto 20%:
Click Start-->Run-->type "gpedit.msc" without the "
Local Computer Policy-->Computer Configuration-->Administrative Templates-->Network-->QOS Packet Scheduler-->Limit Reservable Bandwidth
Double click on Limit Reservable bandwidth. It will say it is not configured, but the truth is under the 'Explain' tab :
"By default, the Packet Scheduler limits the system to 20 percent of the bandwidth of a connection, but you can use this setting to override the default."
This will allow the system to reserve nothing, rather than the default 20%.
works on XP Pro, 2000, but no info on Win7 o/s not tested.
Sep 18, 2010 | Computers & Internet
my system restore has been turned off by a group policy "whatever that means"
Resolution 1. Click Start, Run and type regedit.exe and press Enter
2. Navigate to the following key:
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore
In the right-pane:
  • Delete the value DisableConfig
  • Delete the value DisableSR
3. Exit the Registry Editor.
In Windows XP Professional, you can accomplish the above using Group Policy Editor as well.
1. Click Start, Run and type GPEDIT.MSC
2. Navigate to this path:
-> Computer Configuration
--> Administrative Templates
---> System
----> System Restore
3. Set Turn off System Restore to Not Configured
4. Set Turn off Configuration to Not Configured
For standalone Windows Vista systems, use these steps:
Using the Group Policy Editor
If your edition of Windows Vista includes the Group Policy Editor snap-in (gpedit.msc), follow these steps:
1. Click Start, type gpedit.msc and press ENTER
2. Go to the following branch:
Computer Configuration | Administrative Templates | System | System Restore 3. Double-click Turn off Configuration and set it to Not configured.
Note: If the above setting is already set to Not configured, set it to Enabled and click Apply. Then revert back the setting to Not configured, and click Apply, OK.
4. Exit the Group Policy Editor.
Using the Registry Editor
1. Click Start, type regedit.exe and press ENTER
HKEY_LOCAL_MACHINE \ Software \ Policies \ Microsoft \ Windows NT \ SystemRestore 3. In the right-pane, delete the value named DisableConfig
4. Exit the Registry Editor.
If you set the Turn of configuration option to Enabled, the option to configure System Restore on the Configuration Interface disappears. If the Turn off Configuration setting is disabled, the configuration interface is still visible, but all System Restore configuration defaults are enforced, and the Create button is grayed out. If you set it to Not configured, the configuration interface for System Restore remains, and the user has the ability to configure System Restore.
regards
iversh
if you felt i ve spent my time for answering your query.... kindly rate the service very helpful
Aug 30, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
I am unable to get the double arrow when I clicl the mouse to increase the size of the taskbar. If I go into properties the lock taskbar is grey shade of colour with a tick in the box which I am unable to change. Any ideas folks as its driving me insane.Thanyou
This problem is related to group policies or a registry error as outlined at the below link:
http://www.winxptutor.com/unlocktb.htm
WINDOWS XP HOME:
  1. Open regedit by going to Start -> Run -> type "regedit" (without quotes).
  2. Navigate to HKEY_CURRENT_USER \ Software \ Microsoft \ Windows \ CurrentVersion \ Policies \ Explorer
  3. In the area to the right, delete the LockTaskbar entry and close the registry.
Your problem should be fixed.
WINDOWS XP PRO
  1. Go to Start -> Run -> type "gpedit.msc" (without quotes)
  2. Go to User Configuration.
  3. Then to Administrative Templates.
  4. Then to Start Menu and Task bar.
  5. Change the Lock the Taskbar policy to "Not Configured" (without quotes).
Your problem should be resolved.
Mar 04, 2009 | Gateway GT4022 PC Desktop
320 people viewed this tip
David Payne
David Payne
