Tip & How-To about Computers & Internet
Change your windows font
Irst right clcik on your desktop ,go to properties
-den go to the appearnce tab and select advanced
-den scroll down to the part icon
-you can change your windows font there
Computers & Internet Logo
make icons smaller
Assuming you're talking about your desktop icons, here's how that can be done:
    1.If you're using Windows Vista or higher, you just need to right click on the desktop and point to view and the select the size that you want.
    2.If you're using Windows XP, follow the instructions mentioned below:
    i.Right-click any empty space on the desktop. A context menu will appear. Select Properties.
    ii.Select the Appearance tab in the Display Properties dialog, then click the Advanced button.
    iii.In the Advanced Appearance dialog, select "Icon" from the Item drop-down menu. Select new size in the Size field to the right of the drop-down menu.
    GuruAid
Apr 14, 2014 | Computers & Internet
how to fix the backlight on a Iqon 8050qxx Laptop
To set the transparent background on the icons, we'll need to open System Properties in Control Panel (or right-click on My Computer and select Properties).
In this dialog, click the Advanced tab, and then the Settings button under the Performance section.
Now scroll down to the button where you'll find a checkbox for "Use drop shadows for icon labels on the desktop". Make sure you check this box if you want transparent backgrounds on the icons
Jan 20, 2014 | Microsoft Windows XP Home Edition
my computer don't any sound.
which operating system desktop or Laptop ??????....
Desktop
If your computer came with a motherboard disc the sound drivers could be on it
Click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers.
Click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct speaker settings.
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
If this does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker.
volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume.
Click start control panel sounds and audio volume advanced speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable).
The speaker plug/outlets is usually at the back of the computer or if its a laptop on the side.
You will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity.
Clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit.
Dust causes static to build up in a computer
http://download.cnet.com/2000-20_4.html
On the home page you should see a search tab just type in what you are looking for.
Tick in either the all software or windows software box
IE: motherboard name audio driver you might have to try a few times to get it right
for windows 7
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers.
Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software.
Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers.
Right click on the speaker icon in the bottom taskbar you will see an array of options select
playback devices make sure it has a green tick and the correct speakers are selected
be updated if you computer came with a motherboard disk the drivers could be on it although
once speakers are connected widows 7 should automatically update the drivers.
Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker.
You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply
Laptop
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it.
If his does not fix the problem
Click start control panel sounds and audio devices you can adjust the volume there also select speaker volume.
You can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the speaker volume icon system select adjust volume
from the drop down list or navigate to the device manager scroll to system devices + to expand system speaker right click properties then select use this device (enable) also you might check the speaker plug/outlets they are usually at the side of the laptop.
You will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good with no dust as dust causes static electricity
dust causes static to build up in a computer
on the home page you should see a search tab just type in what you are looking for
for windows 7
be updated.
If you computer came with a motherboard disk the drivers could be on it although
Sep 29, 2013 | Samsung Computers & Internet
icon short cuts doubled in size. How do I get them back on my desktop to normal size??
Windows XP Right click on an empty spot on your desktop and choose properties then click on appearance then click on advanced option, there you can see one tab named items select icon ,same tab right hand side you can select size of the icon(normal size-32), after that click on OK on both windows this steps should change your icon size.
Windows Vista or windows 7
Right click on an empty spot on your desktop and choose Personalize, now choose the first item on the list Windows Color and Appearance, and then click the last link Open classic appearance properties for more color options,
then click on advanced option, there you can see one tab named items select icon ,same tab right hand side you can select size of the icon(normal size-32), after that click on OK.
Regards,
Shibi P G
Jul 17, 2011 | HP Computers & Internet
Desktop Icons have shadows and a blue box around title. How do i get rid of this ?
This border on desktop icons can be created when the desktop items have been locked, to unlock the desktop web items right click on an empty area of your desktop. Now select Arrange icons by and uncheck 'Lock web items on desktop' if it has a little tick next to it. If you did not have a tick here then Right click on your my computer icon and view its properties, now click the advanced tab and then on the settings button under performance. Now on the visual effects tab scroll down the list of effects to 'use drop shadows for icon labels on desktop' and put a tick in the box next to it, then click ok. This should remove the shadow border from your desktop icons.
refer to:
http://www.ikarmatech.com
Sep 08, 2009 | Microsoft Windows XP Professional for PC
120 people viewed this tip
David Payne
David Payne
