Tip & How-To about Computers & Internet
Mouse pointer with keyboard keys
You can control your mouse pointer with keyboard keys in all windows versions. When your mouse stops working, you can enable this keyboard feature to complete your important work. This keyboard mouse can performs all tasks same like a normal mouse.
Follow the given steps to activate the keyboard mouse:
To edit this feature, first you should log onto your computer with administrative rights.
To activate this feature, press Alt+Shift+NumLock keys at once and you will receive a small MouseKey box.
To keep MouseKeys on, click on Ok button or click on cancel button to cancel MouseKeys box.
Click on Settings button, if you want to adjust the mouse cursor detail settings.
Here a new dialog box will appear with the title Settings for MouseKeys", now you can manage all mouse settings for example mouse cursor speed, acceleration and some other features.
Now using Numeric keypad, you can move your mouse pointer. The controls are:
1,2,3,4,6,7,8 and 9 keys are used to move the mouse cursor into different directions.
Key 5 is used as mouse click button.
Insert key used to hold down mouse button.
+ Sign used to double click on any object.
Delete button used to release the mouse.
Click on NumLock button to disable this keyboard mouse feature
Computers & Internet Logo
Suppose the numeric keypad of a keyboard is not functioning correctly, and when a numeric key is pressed, the keyboard redirects the cursor. Provided that the keyboard is not faulty, which of the foll
what os youre using ?
if windows os then maybe the mouse keys on Accessibility feature was turned on
how to check it on windows 8 :
1.Swipe in from the right edge of the screen, and then tap Search. (If you're using a mouse, point to the upper-right corner of the screen, move the mouse pointer down, and then click Search.)
2.Tap or click Settings.
3.In the search box, enter Change how your mouse works, and then tap or click Change how your mouse works.
4.Under Control the mouse with the keyboard, check the Turn on Mouse Keys check box, if selected then deselect it and then click OK.
On Windows 7 :
1. goto start -> control panel -> ease of access center
2. click on use make mouse easier to use
3. check the turn on mouse keys check box, if it checked then deselect it
4. clik ok
Sep 20, 2014 | Computers & Internet
de activating num lock key only enables cursor movement in four directions. how do you get the number pad to enter numbers?
This is a Windows feature called "mouse keys", it can be disabled by using the shortcut left-alt+left-shift+num lock.
In Windows 7 mouse keys settings can be found by following Control Panel\All Control Panel Items\Ease of Access Center\Set up Mouse Keys
Nov 07, 2010 | Logitech Classic 200 DH968019 Keyboard
i have disabled the mlouse by using the synaptics
press the windows button(win logo) on the keyboard left bottom near the Shift key
use the up/dn/left/right arrow keys to move to the control panel/move to mouse icon in that and press enter/ here if the mouse is disabled / enable it
Mar 15, 2010 | Computers & Internet
Compaq notebook laptop: my mouse pointer or arrow is
If you have a manual for the notebook, check to see if you can use the function key and the similarly coloured key on the keyboard which enables/disables the touch pad. Usually you can disable the mouse pointer touch pad with this FUNCTION key + MOUSE key when pressed together. Often these keys have the same colour (usually blue). The purpose is to disable the touch pad when you are using an external USB or wireless mouse, then you press the 2 keys again together to enable the touch pad once you have removed the USB/wireless mouse.
If that doesn't work, borrow a USB mouse and attach it to your notebook to use temporarily while you diagnose the problem.
Dec 19, 2009 | Acer Aspire 5100 Notebook
Turning Off Pointer Acceleration
Go to Control Panel and click on the Mouse icon. You should be able to decrease the speed by dragging the speed bar to the left. Hope this helps. bud
Jul 19, 2008 | Microsoft Wheel Mouse Optical PS/2 USB...
213 people viewed this tip
David Payne
David Payne
