Tip & How-To about Computers & Internet
HOW TO HIDE UR DRIVE WITHOUT ANY SOFTWARES
You can hide your "private" files using a nifty little registry hack that will completely remove an entire drive from your computer. The drive will not show up in My Computer, will not be accessible from the command prompt, and won't even show up in Safe Mode! Ok, so here's how to implement the hack: first off, back up your registry as this requires adding a key to the registry. Once you've backed up your registry, open the registry editor by clicking on Start, Run and typing in regedit.
Now navigate to the following registry hive shown below:
HKEY_CURRENT_USER \Software\Microsoft\Windows\CurrentVersion\
Policies\Explorer
Right-click on Explorer and choose New and then DWORD Value.
Name the new value NoDrives and then double click on it to open the properties dialog box. Click on Decimal for the Base unit.
Type in one of the following values depending on that drive letter you want to hide.
Code:
A: 1, B: 2, C: 4, D: 8, E: 16, F: 32, G: 64,
H: 128, I: 256, J: 512, K: 1024, L: 2048, M: 4096,
N: 8192, O: 16384, P: 32768, Q: 65536, R: 131072,
S: 262144, T: 524288, U: 1048576, V: 2097152, W: 4194304,
X: 8388608, Y: 16777216, Z: 33554432, ALL: 67108863If you want to hide drive E, just type in the value 16. The really cool thing about this trick is the fact that you can hide multiple drives by adding the numbers of the particular drives together. For example, if you want to hide drive E and drive G, you would type in the number 80, which is 64 + 16.
Restart your computer and your drive will now be hidden! Trying to hide your system drive (C) will not work as Windows has to use this drive to run correctly, so don't store your secret files there!
When you want to get your drives back, change the value of NoDrives to 0 or simply delete the value altogether. Of course, having to do this everyday can be a pain, so if you're up for it, you can try and write a registry file that will allow you to insert and delete the value by just double-clicking a file.
This trick also works for mapped drives, so if you want to hide mapped drives, you can do it this way (though it might just be easier to disconnect a mapped drive).
Enjoy
Computers & Internet Logo
I have CreataCard Platinum 8 version installed on my computer. Recently, I had to uninstall it and then re-install it due to some computer problems. I just tried to access the program and I keep getting a pop-up message that says "Cannot determine configuration." I tried to uninstall the program so I could reinstall it from the discs again, but my computer won't let me uninstall it now! Can you please help me???
Hi.
If you are unable to uninstall the software by way of 'Add or Remove Programs' or 'Programs and Features', it will be necessary for you to perform a manual uninstall by searching the hard drive for files and folders related to the program you want to uninstall. then manually removing those files and folders.
Many programs will install files and folders in several locations on the hard drive. And, even when it is possible to uninstall software by way of 'Add or Remove Programs' or 'Programs and Features', it is always a good idea to conduct a search of the entire hard drive then manually delete any files, folders, icons and shortcuts that are found by that search because many uninstall processes do not remove all files, folders, desktop icons and Start menu shortcuts associated with the software.
After making sure that all files, folders, icons and shortcuts have been removed from the computer, empty the Recycle Bin, restart the computer, then run a registry cleaner until no invalid registry entries are found. It is advisable to run the registry cleaner REPEATEDLY (always restart the computer before running the registry cleaner again) because fixing some invalid registry entries can cause other registry entries to become invalid.
If you are uninstalling the program because you believe that the installation is corrupt, these steps are especially important . Making sure that all files, folders, icons and shortcuts are manually deleted and using a registry cleaner to remove all invalid registry entries is the best way to ensure that all corruptioIf you don't have a registry cleaner installed on your computer, you can download the free CCleaner by clicking on the link below
Download Latest Version of CCleaner
If you use CCleaner, you must remember to click on the 'Registry' button on the left side of the window before starting the scan. And, with CCleaner, running the registry cleaner repeatedly will often cause the same invalid registry entries to be displayed over and over. If that happens more than twice, the only option is to allow those invalid registry entries to remain - because indications are that those invalid registry entries are not truly
invalid at all.
There is also an option to try and uninstall a program using CCleaner. If you click on "Tools" option on the left hand side, click on "Uninstall" and look down that list for Creatacard and try and uninstall the software using that option.
The 'Cleaner' option in CCleaner is a very useful tool for cleaning out unnecessary files and folders on the hard drive. So, it is also be a good idea to run the 'Cleaner' option in addition to the 'Registry' option.
Once you are sure that all traces have been removed restart your computer and proceed to re-install the software again.
Hope this helps.
Regards.
Jun 02, 2011 | Broderbund American Greetings Creatacard...
Disable AutoPlay in Windows Vista Windows Vista's AutoPlay options are a great improvement over Windows XP in terms of flexibility, but unfortunately there are so many options that it can be confusing, especially since there's no specific mention of USB Flash drives in the options. Open your Control Panel, and then click on "Play CDs or other media automatically" to open the AutoPlay dialog. Disable AutoPlay Globally The quickest way to disable AutoPlay entirely is to just uncheck the box for "Use AutoPlay for all media and devices", which should usually work. Disable for a Single Type You can choose a setting in the drop-down menu for a single type of drive, for instance Audio CD in this example. For this to work you'll have to make sure to keep the global autoplay option on, and then choose the specific setting in the drop-down. Disable for just Removable (flash) Drives The problem here is that while there are settings for Audio CDs and DVDs, there's nothing specifically for USB flash drives. Windows will determine the drive type based on the content it finds on the flash drive itself, so that's what we'll need to change. In order to disable AutoPlay for the removable drives, you should change all of the following to Take no action: Software and games, Pictures, Video files, Audio files, and Mixed content. Disable Through Group Policy A number of readers have written in complaining that the option to disable autoplay isn't working for them, so if you'd like to disable it entirely you can use the Group Policy editor on the Business and Ultimate versions of Vista. Open up gpedit.msc through the start menu search box, browse to Windows Components \ AutoPlay Policies, and change the value of "Turn off Autoplay" to enabled. You can choose whether to disable for just removable devices, or entirely. I'm not sure if that makes any sense, however. Disable with Registry Hack The Group Policy editor is not available on Windows Vista Home editions, so I've also included the registry tweak to disable AutoPlay entirely. Download and unzip this registry hack and then double-click on the appropriate file. DisableAutoPlay.reg will disable autoplay entirely. DisableAutoPlayRemovable.reg will disable autoplay on removable devices.
Jan 01, 2008 | Microsoft Windows XP Professional Full...
286 people viewed this tip
David Payne
David Payne
