Tip & How-To about Computers & Internet
Put a background to your USB flashdrive
Thought you would also be fascinated like me on this one. ...........
Step 1:
Copy this code into notepad (copy and paste), then save it as "desktop.ini"
CODE
[.ShellClassInfo]
IconFile=%SystemRoot%\system32\SHELL32.dll
IconIndex=127
ConfirmFileOp=0
[{BE098140-A513-11D0-A3A4-00C04FD706EC}]
Attributes=1
IconArea_Image="your_picture.jpg"
IconArea_Text="0xFFFFFF"
VeBRA sources - don't delete the tag above, it's there for XXXXX purposes -
[ExtShellFolderViews]
{BE098140-A513-11D0-A3A4-00C04FD706EC}={BE098140-A513-11D0-A3A4-00C04FD706EC}
{5984FFE0-28D4-11CF-AE66-08002B2E1262}={5984FFE0-28D4-11CF-AE66-08002B2E1262}
[{5984FFE0-28D4-11CF-AE66-08002B2E1262}]
PersistMoniker=Folder.htt
Step 2:
Put "desktop.ini" file onto your flash drive and replace "your_picture" with the
name of the picture you want to use leaving the .jpg extension the same.
Step 3:
Now copy the picture that you want to use onto your flash drive.
Step 4:
Refresh (F5) or Go back to My Computer and open your flash drive again ..and enjoy with new background... .....
Computers & Internet Logo
how do I put my signal private
Go to security setting and generate a WAP/WEP key.
Look in your manual, it shows you step by step.
You login to router with a browser, and then simply go to security section, generate the key, save in notepad, save all setting in router, reboot router, Then attempt to login to the WiFi SSID, and it will ask you for effectively a Password, WEP?WAP Key, simply copy paste that number you saved in notepad, and you will now be able to connect.
Jun 11, 2010 | Linksys Wireless-G Broadband Router
when typing my encryption code only numbers work not letters
yes that is still OK, Just copy the numbers into say a notepad document, then save, as say wepkey.txt, then when you need to use the key simply copy that notepad file to the PC you want to use it on and copy & paste the key into the box required.
Feb 15, 2010 | D-Link 802.11g Wireless Router WBR-1310...
I have a Camnex T850, tried to copy a e-book from my old Camnex, The Thorn Birds, and I can't get it to copy, all my other e-books did just fine
#1: Save the e-book to your computer. Open My Documents and press it. Then click Move This Folder and move it to your Camnex.
#2: Copy the text on the e-book and open Notepad. put nothing in Notepad and save it to your Camnex then when it is saved and it again and paste the text from the e-book onto the Notepad. Then save it again.
NOTE: Solution 2 has a bigger chance of working then 1 but 1 might work two.
Feb 01, 2010 | Mach Speed TRIO Onyx MP3 Player
error code: 0XEB020B88 when I try to burn music CD's with cyberlinkDVD suite
do the following
Open Notepad (START>>>RUN>>>type in notepad)
Hit OK
Copy the contents of the CODE box, not including the word "code"
Paste it to the empty Notepad file
In Notepad click FILE>>SAVE AS
Change the Save as Type to All Files.
Name the file as Export.bat
CODE regedit /e Export.txt "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}"
Double click on Export.bat, a text file called Export.txt
should produce on your desktop
Copy>>paste back here the contents of Export.txt
Jun 23, 2009 | Computers & Internet
159 people viewed this tip
David Payne
David Payne
