Tip & How-To about Computers & Internet
A quick, simple approach to troubleshooting Desktop Computers Important : Before doing any of the below steps, do consider the following reminders : It is highly important that you're using a footwear with rubber soles for extra protectionOperate with clean, dry handsNo boot?...No POST?... Machine is ON but there's no video? Here's what to do: Turn the Computer OFF manually - press and hold down on the 'power' button until the system turns itself OFF. While the computer is turned OFF, unplug everything from the desktop including (Mouse and keyboard, power cable, all USB devices, others - network, etc.) Do a 'power drain' - press and hold down on the power button for at least 15seconds (while everything is disconnected) Reconnect just the keyboard, mouse and power cord Turn on the computer and see if the problem is fixed If NOGO, then it's time to contact helpdesk support (usually through phone). Telling them about these steps will ensure a better and faster route in resolving your problem.
Computers & Internet Logo
I. Want them to call me...so I can make arrangement for the payment
It is considered as a good step if you make an approach for installation of Malwarebytes onto your PC. The installation of this antimalware application Malwarebytes Contact Support Phone Number needs to be followed by a specific procedure. After that, it is also necessary to configure it in the proper way inside its home system.
Nov 22, 2017 | The Computers & Internet
need usb recovery
If you need to retrieve files from a USB storage device, it is as easy as using a dependable recovery program designed to perform USB data recovery. This software scans the sectors of an external device to locate and recover these items:
- accidentally deleted files
- corrupted data
- formatted USB drives
- lost or erased files
You see, a recent USB drive corruption or unexpected power outage can wreak havoc on your data. Even a simple file deletion may result in the loss of something important that you desperately need to retrieve. A USB recovery utility offers a reliable approach to quickly salvage your data. It can easily locate files on a USB device for retrieval. Whether deleted, corrupted, or erased during formatting, this program provides an opportunity to quickly get your information back. This video will walk you through the program.
USB Recovery for Mac Computers
Dec 29, 2013 | Aspire Acer AS5315-2856 Laptop
Dial up connections
not unless you ask for them. they are considered an ancient approach, and most folks actually don't use them even for faxing.
Apr 27, 2008 | Computers & Internet
HP IPAQ POCKET PC
1st approach (Quick one!)
1. Soft reset your device
2. make a backup copy of the folder \SD-MMCard\MSMETADATA if exists.
3. delete the folder \SD-MMCard\MSMETADATA.
4. Soft reset your device once again.
2nd approach (Long one!)
If 1st approach did not work, restore the MSMETADATA folder and try the following:
Step Zero: BACKUP
- Make a full backup of your device (including storage cards). If you don't like to do a full backup keep at least a backup of all files and folders we are going to delete as indicated below:
Step One
-In the main device directory delete the file WMPInfo.xml
-Delete the \Application Data\Microsoft\Media Player\ directory and all of
the files in it including the WMDRM folder.
-Delete the \Music folder
Step Two
-Go to your SD card main directory and delete the file WMPInfo.xml
-Delete the folder \SD-MMCard\MSMETADATA
-Delete the folder \SD-MMCard\WMDRM
-Delete the folder \SD-MMCard\Music
Step Three
-Repeat step two for any other storage cards.
Step Four
-Refresh devices in WMP and the storages card should show up in the left tab
and in the sync window you can click "Next Device"
Hope this helps...
Feb 25, 2008 | HP iPAQ rx1950 Pocket PC
188 people viewed this tip
David Payne
David Payne
