Tip & How-To about ASUS M4A79T Deluxe ( M4A79T DLX MB PHENOM I) Motherboard
Problem Using Windows Install Disc with RAID? Some Tips:
After going through some issues installing Windows onto a RAID partition using this Motherboard, I found some things that were helpful.
#1 Install hangs, or I get an error after Installing RAID Driver. Nowhere in the manual does it tell you this (or at least I didn't see it) but when you install the RAID driver during the windows install, the Motherboard automatically sets SATA connectors 1, 2, 3, and 4 to be RAID. That means if the DVD/CD Rom you are using is plugged in to any of those connections, the minute you install the RAID Driver, the Optical Drive will no longer work. You have to use SATA 5 connector on the motherboard for your optical drive
#2 Multiple Optical Drives with RAID. Because of the issue in #1, there is really only 1 internal SATA Port you can plug an Optical drive into when you have RAID configured. There are some solutions if you want more than 1 Optical Drive alongside your RAID configurations.
You can use the ESATA port on the back of the Motherboard with an extra-long SATA cable. If your case has grommets on the back for water-cooling lines, you can run the cable through there, or just in an unused PCI slot on the back.
You can use an old-school PATA DVDrom. If you are installing 2 Optical drives, and one is a DVD burner or reader, you could get a PATA DVD Burner or reader instead. This Motherboard does have a good old fashioned ribbon connection, so it's possible. Typically DVDs or CDs don't move enough data to see a difference between PATA and SATA, but when you start getting into any DVD reading/Writing above 8X or so, you will be throttled.
Get a PCIe controller card. I think of this as the last resort for this board because of it's possibility with graphics cards. Hooking up anything unnecessary to any of the PCI slots would be defeating the purpose of having 2 full 16X PCIe slots. You might be able to squeeze one in on one of the 1X connections, or maybe the bottom full slot, but it could get cramped if you have 2 or more Video cards.
#3 Windows Installation Issues. DVD Drive Stops Reading during install. I had this issue even after finding out my issue from tip #1. I found that some windows install discs mixed with some manufacturer's DVD drives don't get along well. It would start the installation OK, and get most of the way through it, then it would hang and throw up an error. It seems that during Installation, the SATA DVD drive decides that doesn't like the generic drivers anymore, and just stops working. I fixed this by pulling a PATA DVD drive out of an older PC to use until Windows was fully installed. Once Windows was installed, I pulled that drive back out, and Installed my SATA DVD drive, and Windows installed the drivers with no problems.
#4 RAID Performance. I'm not too sure that I'm getting the best performance from this RAID-0 configuration. I'm running 2 WD Caviar Black 500GB HDDs. My Windows Experience score for the drives is still 5.9. Perhaps the RAID configuration would work better with some faster drives, like Samsung drives, or WD Velociraptors... But I'm unsure.
ASUS M4A79T Deluxe ( M4A79T DLX MB  PHENOM I) Motherboard Logo
RAID drivers in Windows 7 Ultimate 64bit Setup not detected
Delete the '32bit' folder from your USB drive, and try again to re-install Windows. Hopefully, it will find the '64bit' folder, and will install from that folder.
Mar 01, 2010 | Microsoft Windows 7 Ultimate for PC
I have recently purchased a new HDD (I now have 2 Hitachi P7K500 HDDs) and built it into my system. I have first formatted the HDD I already had, then configured my BIOS for use of RAID 0. My mobo (MSI K9A2 CF-F) btw has an on-board RAID controller which supports RAID 0, 1 and 0+1. (I changed the RAID setting in the BIOS from value IDE to value RAID. This triggered the RAID BIOS to launch on startup, so I need to have that selected to run RAID.) That all went well. Then I decided to reinstall my OS (Windows 7 Ultimate 64-bit) again using my LG GH20N DVD burner/reader, so I used the same drive and disk I have used successfully before. (I have installed Windows 7 like 5 times on that PC) However, during installation, when normally the window asking you on which partition you wish to install Windows would pop up, I get an error message, saying: "A required CD/DVD drive device driver is missing. If you have a driver floppy disk, CD, DVD, or USB flash drive, please insert it now." This never happened before...I decided to google for a fix, but found nothing. (I found solutions for people using corrupt ISOs (reburn) or using old DVD drives (buy a new one), but the ISO I burned is OK, because it worked fine when I didn't run RAID, and my DVD drive also worked without running RAID. And the RAID array is the only thing I changed in my hardware configuration. (I even disabled RAID, and lo and behold, the setup ran fine!) Sadly, there were no fixes involving any kind of RAID. I need you to find me a driver that will fix this error message, so I can install WIndows 7 on my RAID 0 array. I can burn the driver to a CD-R or copy it to a USB stick, so that won't be a problem. Here's my specs again: Mobo: MSI K9A2 CF-F DVD drive: LG GH20N Windows 7 Ultimate 64-bit Thank you already, Yannick Verhoog.
1. If you are just setting up your computer to have an a regular HDD and Backup HDD, i would think you should be able to set that up by booting onto your computer regularly, go to start, then into My Computer and right clicking on the HDD you want to set as Raid 1.
But if just want that other HDD for Space on your computer, all you had to do was plug it in and there you go... extra space.
Now if your installing windows 7 on the other drive i would find that pointless because you already have it on your first drive unless your putting 2 operating systems onto your computer.
Hope this helps.
Feb 27, 2010 | Microsoft Windows 7 Ultimate for PC
Scrambled BIOS Setup on MS-6570 MSI K7N2G-ILSR Motherboard
If you are using windows XP for you're operating system you can use MS disk manager to delete the XXCLONE partition. Click the start button, click run and type in; diskmgmt.msc
Once in disk manager use the help button as you're guide.
Cheers'
Mike
Feb 07, 2010 | Computers & Internet
convert to raid 1 after Vista install
Install at least 2 more hard-drives, and configure them to use RAID.
Then, copy/move all your data-files from "My Documents" onto the new drive-set. The point here is to have "backup" for your files, not for the Operating System files (which can be re-installed from CD/DVD).
Your "programs" can stay on the "current" disk-drive.
Sep 10, 2009 | Intel DP45SG Motherboard
Unable to see RAID 5 config on Asus kfn32-D SLI/SAS MB
NVIDIA RAID does not support > 2TB (18xxGB) arrays. It will NOT show up properly in Windows.
Feb 20, 2009 | ASUS KFN32-D SLI /SAS Motherboard
2,939 people viewed this tip
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
