Tip & How-To about Office Equipment & Supplies
Important tips
In summer weather, paper can become moist and cause more paper jams than normal. Keep your paper in either plastic bags or large tubs with a sealing top.
Copiers can be very affected by static, which can cause damage to it. Place a rubber mat in front of it and make sure the installer properly grounds it. The copier should be plugged into a surge protector.
Turn off office equipment at day's end to save energy.
How do you soften Hard Brown Sugar ?
Warm water with yeast will turn it into alcohol
Mar 03, 2015 | Miscellaneous
intermiten paper jam
Try putting printer paper in a sealed plastic box with a moisture absorbing device like in pill bottles. Moisture may be cause depending on weather and humidity.
Nov 06, 2013 | NEC My Office C350 Printer
paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
water leaks from under the middle but not all the time maybe once or twice per month
condensation normally drains thru a tube at the bottom of the frig to a drip pan under the condenser coil (under the frig) .. the water normally just evaporates from the pan .. if there is too much moisture in the frig, that usually means a door is ajar (not closing completely) or the seal on the door is not sealing properly .. warm moist air from the room getting in will cause too much condensation .. the drip pan may overflow ... you should check the drip pan for damage (clean the condenser while you are down there) .. also check the tube that carries the condensation (back bottom of the frig) .. it has a one way valve (lets water out only) that becomes stuck sometimes and needs cleaning.. if there is a large amount of moist things in the frig then that an cause the problem as well .. just put those things in plastic bags or containers to eliminate that problem ..
Nov 21, 2009 | Amana AFD2535DES French Door Refrigerator
photo's do not print. sometimes only 1/4 of the photo prints, sometimes nothing and it feeds more paper.
Paper may be moist. Summer humidity can cause these type of problems particularly with coated stocks.
Printers (the people) always "laid out" paper to dry before color runs as even from factory the would be sufficient moisture to cause bleeding and misfeeding.
Try to keep your stuff in a air condition room if possible during humid times.
Regards
Apeal
Aug 21, 2009 | Canon Office Equipment & Supplies
242 people viewed this tip
jasbo
jasbo
