Tip & How-To about Garden
Safety For Riding Mowers
  • Do not give children rides on a riding mower, even with the mower blades not turning.
  • Children may fall off and be badly injured or interfere with safe machine operation.
  • Children who have been given rides in the past may suddenly appear in the mowing area for another ride and be run over or backed over by the machine.
  • Do not mow with a riding mower in reverse unless absolutely necessary.
  • You can be seriously injured or even killed if you use a riding mower on too steep an incline.
  • Using a riding mower on a slope that is too steep, or where you don't have adequate traction can cause you to lose control or roll over.
  • Always consult your operator's manual for safety messages concerning operation on a slope.
Garden Logo
ATCO sit on mower. Engine cuts out when I engage the blade. Help? Maria
Most sit on mowers and riding tractors have an "operator present" switch beneath the seat. If this switch is not activated then engaging the blade will cause motor shutdown - which is what you want if you fall off the mower or even stand up off the seat. The switch could be disconnected, defective, loose or messed up with dirt. Be sure this part is working and I'd expect you will have it fixed.
Jun 27, 2016 | Garden
Mower Engine shuts down when cutter engaged
With the spark plug wire(s) disconnected, tilt the mower and try to turn the blade. The blade bearing may be seized. Do you hear the belt screeching ? That would be a good clue.
Mar 07, 2015 | Garden
riding mower starts, but dies when blade engaged, or clutch/brake released
The safety switch that turns off the engine when you get off the seat is probably disconnected, broken, or out of adjustment, IT is the most common switch to fail. Many users disable it, but then you assume the liability if someone is injured due to the bypassing of the switch. It is sad that manufacturers have to install all these really unneeded features when a little common sense from the users would eliminate the need for them entirely.
Sep 16, 2014 | Garden
how do i turn off airbag 2001 mercury sable
It is not able to be turned off on your vehicle. you would have to physically disconnect the air bag, then none would work. Children that young should not ride in the front seat anyway.
Jun 11, 2009 | 2001 Mercury Sable
need a car seat manual
Types of car safety seats at a glance
The chart below is a quick guide on where to start your search. However, it’s important to read more about the features and how to use your car safety seat.
Age Type of Seat General Guideline Infants Infant seats and rear-facing convertible seats All infants should always ride rear-facing until they are at least 1 year of age and weigh at least 20 pounds. Toddlers/Preschoolers Convertible seats It is best to ride rear-facing as long as possible. Children 1 year of age and at least 20 pounds can ride forward-facing. School-aged children Booster seats Booster seats are for older children who have outgrown their forward-facing car safety seats. Children should stay in a booster seat until adult belts fit correctly (usually when a child reaches about 4' 9" in height and is between 8 and 12 years of age). Older children Seat belts Children who have outgrown their booster seats should ride in a lap and shoulder belt in the back seat until 13 years of age.
Mar 28, 2009 | Evenflo Ultara I Premier
207 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
