Tip & How-To about Garden
Safety for All Mowers
  • Be sure to completely read the safety information contained in the operator's manual.
  • Never tamper with safety devices. Check their proper operation regularly.
  • Tragic accidents can occur with children.
  • Do not allow children anywhere near the area of operation.
  • Children are often attracted to the unit and mowing activity.
  • Never assume that children will remain where you last saw them.
  • If there is a risk that children may enter the area where you are mowing, have another responsible adult watch them.
  • The blades on mowers spin very fast and can pick up and throw debris that could seriously injure a bystander.
  • Be sure to clean up the area to be mowed before you start mowing.
  • Do not operate a lawnmower with the discharge guard (reflector) or engine grass catcher installed.
  • The Mower Deck has spinning mowers blades that can amputate hands and feet.
  • Do not allow anyone near the mower while it is running.
  • Always allow the mower blade(s) to stop completely before leaving the mower's operator position.
  • Always turn off mower when crossing a sidewalk or a driveway.
Garden Logo
ALTEC BUCKET TRUCK STABILIZER CYLInDERS WON'T RETRACT
make sure that the truck is in the ready to move configuration--
bucket properly stowed booms in etc as there may be micro switches that will not allow pressure to return from the cylinders until this is all achieved
The system has safety devices that will not allow operation until it is properly leveled or will not allow stabilizer operation until the machine has been properly made ready for travel
read your operators hand book and safety instructions
Jan 17, 2016 | Custom Manlift Hydraulic Scissor Lift...
I have a Saturn 2001 4door s series the security light is on and won't start what can I do
Passlock
The passlock system is a vehicle theft deterrent system which deters drive-away vehicle theft by disabling engine operation if the ignition lock cylinder is not rotated with the proper mechanically cut key.
The passlock system is made up of an ignition switch assembly, passlock sensor, body control module (BCM), instrument panel cluster (IPC), and a powertrain control module (PCM).
The ignition switch contains a magnet mounted on the lock cylinder and a passlock sensor assembly which consists of security hall effect sensor, tamper hall effect sensor, and output resistors. A drill proof metal shield is also staked over the sensor housing.
The passlock sensor mounted to the ignition switch assembly is located inside the upper right side of the steering column. The passlock sensor contains two hall effect sensors: a tamper hall effect sensor and a security hall effect sensor. The tamper hall effect sensor is mounted on top of the security hall effect sensor. Should someone attempt to defeat the system by use of magnetic experimentation, the tamper hall effect sensor will activate first.
The BCM has the passlock controller integrated into it which controls the majority of the security systems logic. The BCM reads the data from the passlock sensor continuously. If the data is correct and has been received by the BCM within a specified time, the BCM will send a coded password to the PCM. The PCM will then allow the fuel injectors to operate.
The coded password for the security system is sent from the body control module to the PCM via the class 2 data link. If the password is correct and received within the specified time, the PCM will allow the fuel injectors to operate.
The IPC contains the security telltale. The security telltale has three modes of operation, OFF, FLASHING, and ON.
SECURITY TELLTALE will be off if:
Ignition is in the OFF position
Ignition is in the RUN, START, or ACC position and security system diagnostics have all PASSED
SECURITY TELLTALE will be on if:
The BCM is performing a bulb check at vehicle start
Security system diagnostics have not yet completed at vehicle start
A security system diagnostic trouble code (DTC) is set in the BCM or PCM
SECURITY TELLTALE will be flashing if:
The tamper hall effect sensor has been triggered
Incorrect passlock sensor data to BCM for more than 5 seconds during vehicle start
No passlock sensor data to the BCM for more than 5 seconds during vehicle start
Incorrect password from the BCM to the PCM after 5 seconds during vehicle start
Oct 23, 2015 | Saturn Cars & Trucks
operating system not found dell inspiron
There are some possibilities:
1. There is a bootable device (such as USB flash drive) attached to this laptop, but the device does not have proper operating system,
2. There is a media in the DVD drive, and it does not contain proper bootable system,
3. The hard drive is dead, so the laptop does not find any bootable device,
4. The hdd boot sector is damaged,
5. The required boot files are missing or damaged.
You can check:
- 1 & 2: check the laptop and the dvd tray,
- 3, 4 & 5: Check using DVD reinstallation media. It will check and try to install an operating system, so it will detect the previous operating system. There is an option to repair the previous operating system, so you need to read the available options. If you have valuable data in this hard drive, then you need to take out the hard drive and copy the data to the other data storage.
Mar 01, 2014 | Computers & Internet
have been given a, "used" Edu Science 525x reflector telescope (set) in case. I,m looking for the following help .... 1) needs to be inspected,and overall cleaning done', and adjustments made to be sure it is all there, and working properly. .. 2) Also need to get, a user guide, and instruction book for it, if possible, so can operate it properly, that shows the different lens, and their operations, and how to assemble ,where they go. Can you help me find this information, or locate a place that i can contact to handle these things . THANK YOU
This is sold by Toys R US. You will not find a manual. It will NOT achieve 525x that is a complete lie. Maybe 100-150 power.
Meade has manuals for all of their telescopes. Look under the REFLECTOR topic for one that is similar to your telescope. They all assemble the same way.
Then read my TIPS on my profile page.
Here is Meade's manual web site:
http://www.meade.com/manuals/index.html
Foe information on cleaning optics read this:
http://www.televue.com/engine/page.asp?ID=143
Mar 07, 2010 | Edu-Science Optics
183 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
john h
