Tip & How-To about Heating & Cooling
Airconitioners tips
  • Check all hose connections for leaks. Repair leaks
  • Make sure the condensate tube is draining freely.
  • Change or clean the furnace filter once a month. This is especially important during the summer when dust and allergens circulate.
  • Clean the outside compressor by spraying it with a hose.
  • Keep plantings at least one foot away for adequate airflow around the entire unit.
  • Vacuum registers and air vents regularly.
  • Have your ductwork professionally cleaned every few years.
  • Keep furniture and drapes away from registers.
  • During the winter, keep the compressor covered and remove window air conditioners.
Heating & Cooling Logo
Ultra SX90 High Eff furnace leaking water from motor. Air filters clear. Water line to the white PVC and to floor drain was not plugged. Looked at the coils and the pan is dry. Air filters clean.
Check drain from bottom of condensing furnace, check that drain hoses are routed correctly. Hoses have to be rerouted if converted to horizontal flow.
Mar 28, 2017 | Heating & Cooling
goodman furnace has 3 blinking lights, indicating pressure switch stuck open. Any help?
The flame sensor needs to be cleaned. This video might help you understand how to clean the flame sensor.
Oct 05, 2012 | Goodman Manufacturing Goodman GMH950704CX...
I have a Goodman system and I have water leaking from the the small box next to my furnace. I have what looks like 3 lines running from unit to this box. One is a small copper one, another is a line wrapped in insulation and the other is a clear plastic hose. I look at the clear plastic hose that runs to it from the ac unit and it looks clogged with dirt all through it. Not sure if thats the problem. Also a side note, my air gets cool but not cold. any suggestions
the clear plastic hose is the condensate drain .. indeed they clog frequently .. lthat will allow water to overflow the pan that is desined to capture condensed water from the evaporator.. the plastic hose and the pipe it is attached to need to be cleaned out periodically ... allowing water to overflow can damage other things so its important to get the drain cleared .. however that drain has little to do with cooling efficiency .. your lack of cooling performance could be another problem ... sometimes the evaporator coil gets clogged (large finned unit behind where the overflow hose is attached inside furnace) .. that has to be cleaned once in a while but is tricky to do ... how often depends on how good the furnace air filter is and how often its changed ... as the evaporator becomes clogged with dust the cooling efficiency goes down .. same with the outdoor unit ... you have to wash out leaves and such periodically from the condenser coils .... if every thing is clean but the cooling efficiency is still low then have the unit checked for refrigerrant pressure .. it could be low .. of course make sure the furnace filter is not clogged ... also for cooling make sure all of the registers are open ... closing some can reduce overall efficiency ... make sure the outdoor unit fan is working properly ..
Jul 25, 2010 | Goodman Heating & Cooling
Water leaking out the bottom of my Furnace
One of the drain tubes (overflow) is plugged. Unhook each one and clear them of any debris.
Dec 20, 2009 | Goodman GMS90703BXA Heater
GMPN goodman furnace: Water leaks from the base.
Check the drain tubes inside the furnace. There may be a loose connection or a split tube.
The unit could also leak from the gasket between the secondary heat exchanger and the vent fan housing. The secondary heat exchanger ould also be leaking or cracked.
Hope this helps.
Matt
Jan 08, 2009 | Heating & Cooling
310 people viewed this tip
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
