Tip & How-To about Computers & Internet
Laptop screen cleaning
The screen is the most expensive component of your laptop. Adequate care must be taken while choosing the cleaning spray. Harsh sprays could turn the screen yellow, and may even cause cracking. Use plain water or vinegar to clean the screen
Computers & Internet Logo
How do l clean the dryer lent screen
HI,The best way to clean the dryer lint screen is physically very careful with your hand remove the lint on the screen and place the removed lint in the garbage.If you have a garden hose,set it to a spray and spray down the screen outside,if that is possible.Do not use heavy pressure on the spray setting as you do not want to spray the water to hard and rip the screen.Take a spray bottle with white vinegar and mix water and vinegar in the spray bottle.Spray down the screen with the water and vinegar mixture.This will help clean and sanitize the dryer lint screen.Then just let the screen dry outside in the sun.Now you have a clean and sanitized dryer lint screen.I hope this helps you.Carrie
Oct 14, 2014 | Dryers
Bottom of my Bosch dishwasher not cleaning dishes, top tray OK have cleaned / taken apart
Carefully inspect the lower spray arm for a crack or separation.
Also inspect the holes in the spray arm that may be stopped up with debris.
Remove and clean the filter in the front center of the tub.
Set the spray arm at the 12 o'clock position and start the washer. After 30 seconds open the door and check the position of the spray arm. Do thi several times to confirm the spray arm is rotating.
Feb 26, 2010 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Clean the MobilePro system
Routine cleaning for MobilePro devices. Caution: Do not spray any cleaning fluids or foam directly onto the MobilePro unit. Caution: Never use harsh solutions, household cleaners, or spray cleaners that contain caustic materials on the MobilePro. Clean or dust the system as follows. · Display screen - Carefully wipe the LCD screen with a soft cloth or a screen wipe designed for that purpose. Special screen wipes are available through your local computer dealer. · Keyboard - Carefully wipe the keyboard with a dry soft cloth. · External case (with LCD closed) - Carefully wipe the case with a slightly damp, almost dry cloth.
Sep 14, 2005 | NEC MobilePro 250e
179 people viewed this tip
David Payne
David Payne
