Tip & How-To about Computers & Internet
When buying new battrey
When buying a new laptop or a second laptop battery, pay attention to the power specs. Generally speaking, you need to know how many cells the battery has. The more cells, the longer the battery can last on a charge. For example, a 12-cell battery is designed to last much longer than a six-cell battery. Alternatively, the specs might list Watt-Hour rating, or WHr. The higher the number, the longer your battery should last. Some computer makers, such as Apple, describe laptop batteries in terms of WHr, while others use cells.
Computers & Internet Logo
How long should battery life last on a Toshiba laptop
Generally speaking, there is liquid battery out from inside, such batteries should change a, such cells have no power biggest, not the normal power.
PANASONIC Lumix DMC-FZ18 Charger
PANASONIC DMW-BLB13E battery
Oct 26, 2011 | Toshiba Computers & Internet
My daughters Dell is only 4 weeks old, you push the power button and the light on the button illuminates for about 10 seconds, nothing appears on the screen and then it shuts off. Have true about 15 times now.
Hello sean_gillett,
Remove power completely from the device. If it is a laptop, remove the battery. Wait about 30 seconds for the power to drain, then reapply the power source.
If it's a laptop, you may need to let it charge 15 or 20 minutes. A desktop should power up just fine. If it does not, contact Dell immediately for warranty repair!
If this helped you, please give me 4 thumbs up!!
Jul 06, 2011 | Computers & Internet
After i replace the battrys, i have problems with the LCD display I see only parts of the display can you tell me how to fix it? or i need to buy a new one?
hi,
the new battery may be leeked or empty of power .
exercise by some other batteries.
pay attention to requested voltage and amper .
has your device shocked?
if yes , you must refer to the expert serviceman . or if has gaurantee , use it .
otherwise you know and your bank account which to buy a new one or not.
good luck
gorbesia
Jun 13, 2011 | Cameras
just wanted to know how much a person would pay for one that is offered street value
It totally depends on what model phone you have...
But generally speaking you may expect to pay about half cost of what a new one would cost, IF it i is good condition. If the phone is in poor condition then much less...
heatman101
May 21, 2011 | Cell Phones
My Compaq Presario C500T lap top won't start
Generally speaking, an orange power light indicates problems with the power. You also described to a "T" how a bad battery behaves. To test this theory, take out the battery and plug in the laptop. It should power up and run. If so, it's time to invest in a new battery.
To be doubly sure, if you have anyone with the same laptop as yourself, plug in their battery to your laptop. It should work if their battery is good.
Thanks for using fixya.com. Please rate this tip accordingly if it provides the information you needed.
Jan 13, 2009 | HP Compaq Presario C500t Notebook
181 people viewed this tip
David Payne
David Payne
