Tip & How-To about Office Equipment & Supplies
HP Print Diagnostic Utility
This toll will help you solve issues for your HP Printer.
This tool is created by HP and I only want HP users to maximize this to help them isolate why there are errors in using their printer.
I am only sharing these to you guys just in case you dont have any idea about this tool.I hope this can be useful.
Description: HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility.
Fix/Enhancement: This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Download the file here.Copy and Paste it in your browsers address bar then enter.
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=mp-91788-1&lc=en&dlc=en&cc=us&os=4063&product=2510767&sw_lang=
Your's Truly,
Christian from HP
Say "Thanks" by clicking the thumb icon in
the post that helped you.
Please click "YES" in solution that solves
your problem as "was this helpful?"
(Although I am employed by HP, I am
speaking for myself and not for HP)
Printhead problem in HP Printer. Need HP Printer Technical Support Number.
For printehead problem you need to reset your printer. First reset your printer then it will automatically resolve. If you want to talk to HP Printer Technical support experts then call at Toll Free Number 1-888-924-5460
HP Printer Technical Support Toll Free 1 888 924 5460
Oct 22, 2016 | HP Office Equipment & Supplies
sir i am havig HP lazerJet 1020 plus printer
Don't worry! It can be happen due to the fault cartridges or the poor paper quality, and the printer roller is no working properly. At that time, it is better to adjust or reload the paper, clean your HP printer if you see any dust, and replace the cartridge as well. For more details, visit :
http://www.hpprintersupportusa.com/hp-customer-service
Dec 16, 2011 | HP LaserJet 1020 Printer
the print heads are not puting out ink like it should it will fix with the tool button then you print and it goes out after 3or 4 papers it skips lines and leaves lines out all together
please follow the onscreen instructuions from the below mentioned URL and hopefully this should fix the problem
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01628836&cc=us&lc=en&dlc=en&product=2512009
if the issue is not solved then print a test page from the printer by the folowing step
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01446360&cc=us&lc=en&dlc=en&product=1153481
if still the issue is not solved then reset the printer by the below step
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00703613&cc=us&lc=en&dlc=en&product=1153481
if still the issue is not solved then call the hp toll free number 1800-474-6836 they will replaced the printer if the warranty period is there .
Best of luck.
hope your issue gets resolved
thanks
regards
hamid
Feb 25, 2010 | HP Officejet Pro L7680 All-In-One Printer
All my documents are stuck in queue. Please help
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01072463&cc=us&lc=en&dlc=en&product=421991
if the issue is still not solve then try to print a test page from the printer if it prints then fine if not then reset the printer by the below step
without turning the printer off remove the power cable from the back of the printer
wait 20-30 second and plug the piwer cable into the back of the printer
use the on button to turn it on .
We are here to solved your issue please send your issue.we will be happy to help you.
thanks
regards
hamid
Feb 25, 2010 | HP OfficeJet 6210 All-In-One InkJet...
how can i do hp Laserjet M1522 printer online?
If you have any doubt in my mind related to hp printer then you can call on 1-888-924-2961 toll free number anytime for hp printer support. Technical Support For HP Printer
Jan 27, 2010 | HP LaserJet M1522nf Multifunction Printer...
405 people viewed this tip
k24674
