Tip & How-To about Computers & Internet
How to connect external tv box to your pc ?
Simply
1- vedio connection
connect the monitor data cable to the the external tv box and take the out data cable from external tv
connect to your pc
2- sound connection
take sound cable from tv sound out to line in pc ( don't forget to open line in , in the sound properties )
3- finally connect the the adaptor to the tv box and play all
best regards
Computers & Internet Logo
broken screen. how to plug in ext. monitor? thanks. ken.[kotynset@gmail.com] 0458037769
Laptops have a 15 pin DSub video connector. Just connect an external monitor to this video connector, power up the external monitor first and then boot up your laptop. The video data will automatically divert to the external monitor.
Sep 04, 2011 | Computers & Internet
Got a 19" LG LCD
To convert a LCD Monitor into a TV
Instructions
    • 1
      Compare internal and external TV tuners that are designed for use with computers. See if the tuner supports HD, DVI, component video, S-video, stereo, surround sound or other features you might like to use. Ensure that any internal devices will work with the expansion slots in your computer.
    • 2
      Purchase a regular TV tuner if your monitor has S-video, coaxial or RCA inputs. These can be seen at the back of the monitor. S-video should be clearly marked; coaxial is a large round port, and RCA inputs are typically smaller and brightly colored. If your monitor does not have these inputs, purchase a special TV tuner designed just for computer monitors. If you would like to use the tuner with your computer and monitor, choose an internal TV tuner. If you're using your computer monitor as a television on its own, select a stand-alone external tuner. Install the internal TV in your computer, if applicable.
    • 3
      Connect the TV tuner to the monitor with the proper cable. Select S-video as the connection option if both your tuner and monitor support it. Choose RCA component video as your next option. Use coaxial only if your monitor and tuner do not have the aforementioned connections. If your monitor has none of these connections, use a standard VGA cable to connect the tuner and monitor.
    • 4
      Connect the tuner's audio outputs to your monitor's speakers. If your monitor has no speakers directly attached, connect external speakers to the TV tuner. This can usually be achieved using regular audio or RCA cable.
    • 5
      Install an HD antenna high on a wall if you will be picking up free over-the-air television signals with your monitor. If you will be using satellite or cable TV with your monitor, simply plug the satellite or cable set top box into the tuner using RCA or coaxial cables. Then connect the tuner directly to the monitor.
    • 6
      Set your tuner to the channel you use to pick up television stations. If you receive free over-the-air television, this channel will be 3 or 4. If you have satellite or cable TV, this station is determined by your television service provider. Check the documentation that came with your system to determine which channel to set the tuner on. You will probably need to change channels using the satellite or cable box rather than the TV tuner.
May 09, 2011 | Televison & Video
how to connect a sabrent external tv tuner box
simply
1- vedio connection
connect to your pc
2- sound connection
best regards
if you see that is helpful plz dont forget to vote me
Apr 02, 2011 | Computers & Internet
i want odyssey 501tv tuner internal driver software
i suggest u try the external TV tuner box...as those do not require any driver...not any installation of software...also it does not require ur computer to work...just ur monitor to be ON...
just connect ur monitor and computer thur the external TV tuner box and connect the TV cable to the tuner box...
Dec 23, 2009 | Computers & Internet
cant hook dvd/vcr to my cable box the manual says I need a extern
The cable box IS an external tuner.  You should connect the video output (either S video, HDMI, or component video) of the cable box to the video input of the DVD.  Then connect the audio output of the cable box to the audio input of the DVD via stereo RCA cables.  If your tv monitor has multiple inputs (ie: video 1, 2, and 3...) connect the video and audio output of the DVD to your tv monitor using an alternate video input (if cable box goes into your tv thru video 1, connect the DVD to video 2).  If your cable box only has one output, or your tv has only one input, then just connect your cable box to the DVD as above, and connect the DVD to your tv.
Jun 21, 2009 | Philips Magnavox DVD/VCR Dual Player
168 people viewed this tip
David Payne
David Payne
