Tip & How-To about Radio Communications
How to make a Dummy load for Cb radio
I took a "Pringles chip" rounded container and wound 8.25 ft of fine copper wire around it from top to bottom with a screw up top(bore into cardboard) holding it in place, and a***Shiny" screw **attached to the metal bottom. Then i took 8.25 ft. and placed it inside of the Pringles can. I punched a hole into the plastic lid and pulled through the wire to go to ANTENNA INPUT. Sitting it on top of the radio I let the metal bottom touch the GROUND by a screw. I keyed the radio it matched the same as my Antenna did. It keyed the exact same 1.5 watts and swinging to 4 watts when I whistled on my PC68Xl Uniden 40 ch. CB radio. Make sure both ends are stripped of enamel coating by scraping it off. I use a cigarette lighter for this or my teeth, or rough sandpaper, or nail polisher. The screw up top of canister is not important --it just holds the wire,so to easy wound the wire. I gapped it about 1 inch apart between windings.
Radio Communications Logo
need piece that holds battries in infred lite on my 350,,where do you get parts?
Hello, does this Famous Trail end FT-350 Monocular have just one battery to operate the monocular and IR? Is this batteries holder a plastic plate or a screw in button? If it is a button, then take a piece of round brass stock that is basically the same size the hole that contains the batteries. First have the same size threads and the same size of the bore cut in to the round brass
stock and have it cut to size. It needs to be cut in the correct length, if not it will push the batteries through the battery container. stewbison
Mar 25, 2011 | Famous Trails FT-350 Monocular
burned out lcd on epson rx600 - how do i repair?
Probably not worth the cost of parts to repair.
Pick up a 2nd hand one off ebay.
Feb 07, 2011 | Epson Stylus Photo RX600 All-In-One InkJet...
How can I open a Bose remote contraol. I have remove the only screw I see but it's pretty hard to pop. Any suggestions?
Once screw is removed, pry the bottom gently with a screwdriver. Now apply lateral pressure between to 2 halves, push to the side. there are 3 pressure points on both sides that need to be released. Once open, you'll see a black diode at the top with a copper wire wound around it. Chances are, one side has separated from the board and needs to be re-soldered.
Apr 30, 2010 | Bose Televison & Video
894 people viewed this tip
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
