Tip & How-To about Office Equipment & Supplies
Troubleshooting Laser Printers: Be sure all dip switches are properly set for your configuration. Laser configuration is sometimes done by a control panel of buttons with an LED display that permits you to alter configuration memory. Be sure that the application being used is properly configured for the printer as set up. Fuzzy laser output could mean you have a dirty corona wire or you are running out of toner. Horizontal lines or splotches indicate possible damaged or dirty print drums or rollers. Since some of these components are part of the cartridge, a useful quick fix is simply to change the cartridge. If laser images seem disproportionately long or short, the drive motor may not be moving the paper through at the correct speed. Failure of a laser printer to go on-line might be a communication interface problem. It could also indicate a faulty control panel. Try powering up the printer with the cable removed. If it now goes to "ONLINE" (or "READY"), suspect the cable or its connector. If you are printing totally black pages, suspect a broken or fouled corona wire. If that is not the case, replace the toner cartridge. If the print appears speckled, it is probably the fault of the primary corona grid which is part of the toner cartridge. Replace the toner cartridge. If white streaks appear in your printing, shake the toner cartridge to insure an equal distribution of powder. If that doesn't work, clean the transfer corona assembly. Contamination on the assembly will prevent it from holding the electrical charge needed to attract toner from the drum. A repetitive pattern of printing defects, such as an identical smudge every 2 inches may indicate a defective fusing roller. Try cleaning it according to your hardware vendor's instructions. If that does not work, you may need to replace the fusing roller assembly.
bunn troubleshooting
If you are pressing the secret button behnd the trademark symbol but its not working, you need to make sure the SET dip switch is set on the main PCB. switch off and isolate the machine. Remove the top cover. look at the main PCB behind the front panel and locate the small dip switch on the right side. Set it to the on/Set position to enable the secret button
Mar 10, 2014 | Bunn Dual TF DBC Coffee Maker
reset xerox phaser to factory settings
Try performing an NVRAM reset, located in 'Troubleshooting', 'Service tools', 'NVRAM reset'. I would advise printing out a configuration page first 'Information', 'Information Pages', 'Configuration Page'.
Hope this helps.
Dec 15, 2010 | Xerox Phaser 6360 Laser Printer
installed new yelloe cartridge but printer keeps stating to reseat cartridge
009-340 Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ...imaging drum cartridge. Turn the printer off using the power switch on the left side. Wait 10 seconds, turn the printer back on, and check if the error message...sensor solenoid nip. Turn the printer off using the power switch on the left... (English) 016-720 PCL Error on the Dell Color Laser Printer 3000cn/3010cn/3100cn ... Press Select ( ) to clear the error on the printer. Reset the printer NVRAM: Press Menu. Press the...and then press Select ( ). When Restart Printer appears, turn the printer off and then back on... (English)
KB Article How Do I Configure and Troubleshoot My Dell Color Laser Network Printer? - KB Article - 296059 ...Troubleshooting Guide for My Dell 3000cn-series / 3100cn Laser Printer ...available online for your Dell 3000cn/3100cn laser printer. The troubleshooting...printing, refer to the Dell Laser Printer 3000cn/3100cn Troubleshooting Guide... (English)
Dec 13, 2010 | Dell 3100cn Laser Printer
When i print envelope the return address gets cut off
There are some parameters that must be correct before an envelope will print properly. The M/P tray on the KM-3035 should be configured for the proper envelope size, probably COMMERCIAL 10, (but could be another size...need to measure the envelope) and type should be set to ENVELOPE. When printing from the application,i.e. Word or Word Perfect, be sure to select the proper printer and configure the Print Set-up, print direction, size, etc...You will have these options by clicking file and then print from the application print menu.
Dec 07, 2009 | Kyocera Mita KM-3035 All-In-One Laser...
I cant get the printer to not loose its initialization.
There is a battery i that holds the configuration and it is mounted on the board since it holds the fomat I think the battery is ok
since it holds the format ok you are getting something ( a space or character) in the data stream going to the printer
if you put the printer in manual mode dip switch settings 1 on to and 1 on botom you can do a test print and make sure you have label calibrated sometimes if dat will not it on label the printer wi not print
good luck
Oct 31, 2008 | Intermec EasyCoder 3400 Thermal Label...
318 people viewed this tip
jasbo
jasbo
