Tip & How-To about Office Equipment & Supplies
Printer error (orange or blinking light)
Printererror (orange or blinking light) After your printer has completed its initial startup you shouldhave a solid green light. If the light indicator is blinking or orange oftenthis is an indication of a printer error. For example, this could indicate a paperjam, issue with the ink or toner cartridge, or other serious error. Because there is no standard to what a blinking light or orangelight means if you're getting either of these we suggest referring to theprinter documentation for troubleshooting steps or methods of determining whatthe status indicator is reporting.
do not my printer initialize & red light glow
LP-365W On Line LED Is Solid Red - samsung product ...
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsImportant: Before you perform any type of service on your printer that requires you to... Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ElectronicsDec 2, 2014 - Important: Before you perform any type of service on your printer that ...Any of these conditions can cause the On Line LED to glow solid red:.
Samsung ML-3561N Laser Printer Initialize - Questions - Fixya
www.fixya.com > ... > Samsung > ML > Samsung ML-3561N Laser Printer
ML-2570 Samsung printer having problem orange LED is blinking ... initializing stage green LED glows continuosly,After initializing Printer green LED turn into ... the red light remains on when i switch on the printer.. and it doesnt initialize the ...
Samsung glow plug Printers & Copiers Questions ... - Fixya
www.fixya.com > Forum > Tags > glow plug > Printers & Copiers
Printer Problems...red status light glowing I bought a Samsung CLP-310W a ...Samsung printer having problem orange LED is blinking in initializing stage ...
Reset for Samsung ML-1660 ' FixYourOwnPrinter
Dec 19, 2015 | Samsung ML 1610 Laser Printer
my hp laserjet 1300 printer shows blinking the orange light instead of the green one and I couldn't find out what is the reason
1. Go light/button blinks twice with solid green and orange lights
2. Green light starts blinking with go light twice and then both go off
3. orange light goes off.
4. green light followed by orange light followed by go light cycle twice and a third time by the green light
5.followed by the orange light continuously blinking.
I have already tried the following trouble-shooting:
1. Put in a new cartridge
2. Made sure there is paper properly seated in the tray
3. Made sure all doors closed (I even took off left side to verify no memory cards
4. Verified all doors closed
5. Done a cold reboot by holding the Go button while turning the unit on.
6. Repeated steps 1-5 multiple times.Hope It's resolve all Your Printer Problem,
Or
Still having Problem Then follow Us For HP Support
Mar 06, 2014 | HP LaserJet 1300 Printer
error 5002 che cosa puo essere?
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Sep 26, 2013 | Canon PIXMA iP3600 Photo Printer
hp deskjet d1560 printer light flashing
After your printer has completed its initial startup you should have a solid green light. If the light indicator is blinking or orange often this is an indication of a printer error. For example, this could indicate a paper jam, issue with the ink or toner cartridge, or other serious error.
Because there is no standard to what a blinking light or orange light means if you're getting either of these we suggest referring to the printer documentation for troubleshooting steps or methods of determining what the status indicator is reporting.
http://h10025.www1.hp.com/ewfrf/wc/searchResults?tmp_product=HP+Deskjet+D1560+Printer&product=3374275&tmp_qt=power+light+flashing&lc=en&dlc=en&cc=us
Aug 06, 2010 | HP D1560 Deskjet Printer InkJet
ink wast is full ,
Hi
Try this to reset the error.
Jun 13, 2010 | Canon i80 InkJet Printer
384 people viewed this tip
jasbo
jasbo
