Tip & How-To about Office Equipment & Supplies
Printer Missing Driver
TheMissing Driver Thisis another common problem. You are all geared up andready to print but yourcomputer can not find the right driver to "talk to" theprinter. Why is this?Not all drivers are pre-installed on all operating systemsand as new operatingsystems are released, you will need to install driversyourself. Consult yourprinter manual. You can also most likely find thecorrect driver online at theprinter manufacturer's website. If not though, asimple web search should helpyou find what you are looking for. Tryingsearching for your printermanufacturer, the model and "printer driver."
I can't change the print quality in excel for my Epson WF 3540
A driver component is missing meaning not installed good or not all the drivers for printer is installed.
Jan 30, 2013 | Epson WorkForce WF-3540 All-in-One InkJet...
How to set to scan as pdf not jpg
You need to install a printer driver PDF program on yourcomputer first. There are quite a few freeware PDF writer programs on theInternet you can download one such as CutePDF.
Scan your document then click on File - Print and select the PDF writer as theprinter device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click onthis link :- http://www.cutepdf.com/
Jun 24, 2011 | Office Equipment & Supplies
Canon PIXMAMX347 1. My Print and Fax Screen shows that the "Canon MX340 Series oOffline,Default". How to I get it back to "Idle, Default" which is the equivalent of "Online, Ready" 2. I successfully installed the "wireless printer function" but the "wireless scanner function" does not work and all I get is "communication error or no connection or no scanner selected" 3. How do I make Icons for scanning and also printing appear/come out in the Menu Bar and Dock?
right click on the printer driver and read through all the task you will see online then click on it if the problem persist Delete the printer driver then reinstall it back it will work and make sure you don't have more than one printer driver on your computer iF you does notice the one that is ready when you put on your printer then make that one your default printer driver if this confuse you delete all the printer driver and reinstall new one.
Jan 30, 2011 | Computers & Internet
crazy talk program from Gearhead wont take sn's
1st You download Webcam Driver.
Crazy talk program from Gearhead wont take sn's
After this install the Webcam driver in the system.
Installation of Webcam Driver
Go to the control panel
Click on the System Icon
Click on the Hardware Tab
Click on the Device Manager s
Select the Unknown Device or printer device where yellow Question Marks sign on it.
Right click on it and uninstall it.
After this go to the top of the device manager and click on scan for hardware changes.
Driver installation Wizard start.
Brows Your Driver from the Hard Disk and click on next.
Driver will be install.
Apr 13, 2010 | Gear Head WC755IPT Webcam
239 people viewed this tip
jasbo
jasbo
