Tip & How-To about Audio Players & Recorders
Blu-ray player wi-fi ready vs. wi-fi built-in
Blu-ray players are getting more internet capable and any player made 2010 or later is probably going to have wi-fi or wireless internet connectivity. However not all players are the same. Some Blu-ray players are wi-fi ready while others are wi-fi built-in. What's the difference? Wi-Fi ready players need an extra part called a dongle or adapter stick to make them work with your wireless router and not just any adapter, typically only the one the player's manufacturer offers. Usually this will cost you an extra $80. But Wi-Fi built-in players already have the adapter in them and are ready to go without adding a part. Be sure to check if the player is Wi-Fi built-in, as this is what you want for wireless connectivity.
Why won't it stream or play disk?
Call Kurtis: Why Your Samsung Blu-ray Player May Not Play ...
sacramento.cbslocal.com/.../call-kurtis-why-your-samsung-blu-ray...
KOVRSep 26, 2013 - Blu-ray players aren't the same as DVD players. ... disc compatibility issues arise and firmware updates for our Blu-ray players are ... My BD-C6500 is apparently one of those old blu rays that won't play blu rays. ... If you are viewing netflix streaming thru your samsung bluray then YES it definitely can. Its not ...
play mp4 files on a blu-ray player - MP4 - Streaming Video ...
www.tomsguide.com/answers/id.../play-mp4-files-blu-ray-player.html
Jan 9, 2014 - I see a lot of Bluray players will play mp4 files. ... If it won't do it via the USB port, will it do it if the mp4 files are on a DVD? ... player has a menu, items likeDisc Tray, Netflix (I use this menu choice to watch streaming Netflix), ...
Sony BDP-S590 3D Blu-ray Disc Player with Wi-Fi (Black)
www.amazon.com/...Blu-ray-Player.../B006U1YUZE
Amazon.com, Inc.Sony BDPS790 4K Upscaling 3D Wi-Fi Blu-ray Disc Player. 4.0 out of 5 stars 334 ยท Panasonic DMP-BDT220 Integrated Wi-Fi 3D Blu-ray DVD Player .... With the Sony BDP-S590, you can wirelessly stream music throughout the home to .... at internet.sony.tv as in the past some Sony products won't connect to certain services ...
Amazon.com: Sony BDP-S5100 3D Blu-ray Disc Player with ...
Jan 07, 2016 | Televison & Video
BD F5700/ZA blue disc player will not connect to the internet,Why?
Did you go to the set up wireless connection on the menu for the Blue ray player or did you expect it to connect to your Wi-Fi home network automatically ?
Dec 31, 2014 | Televison & Video
BD-J Error Code: 0108 has come up on my player how do I up grade? I have tried dowoading from a disc and memory stick but the blu ray player won't allow any what can I do?
If your blue ray player has Wi-Fi built-in and you have a wireless (Wi-Fi) home network, the way to do the upgrade is via the Internet by connecting the player to your Wi-Fi home network.
Dec 26, 2014 | LG Televison & Video
Can not connect to wireless network
If the signal strength is low, consider using a simple wi-fi repeater, or relocating the wi-fi router so it is closer to the Player
Mar 23, 2014 | Samsung BD-EM57 Smart Wi-Fi Blu-ray Player
can't connect my blu=ray dvd to my wireless internet
Please clarify your model number. If you have the DMP-BD60, it only has wired networking capabilities. A USB wi-fi dongle will not work (the USB port is only for storage devices). If you are connecting it to a wired port on a wireless bridge (switch) or directly to your wireless router and having trouble with the connection, check your cables and that your network is up. Next check that you have not restricted the number of devices allowed to connect to the router. There are ways to limit the number of IP addresses in the router setup. If you allowed 4 addresses and the blu-ray player will be number 5, you need to adjust the settings for your router.
Please add a comment with the model number if you are using a different blu-ray player. I hope this helps.
May 05, 2012 | Televison & Video
311 people viewed this tip
 Grubhead
Grubhead
