Tip & How-To about Paradyne BitStorm 2600 (2611-a1-430)
Price of bitstorm 2600 ip dslam
is there anyone can let me the price for this paradyne bitstorm 2600 ip dslam ?
thank you so much !
Paradyne BitStorm 2600 (2611-a1-430) Logo
i need to know if paradyne 2600 is ipv6 compatible
On bridge mode, DSLAM and modem are transparent to IPv6.
On routing mode, IPv6 is not supported yet.
Pls correct me if im wrong, tq
May 03, 2011 | Paradyne BitStorm 2600 (2611-a1-430)
How to reset Paradyne (1740A1400) Router ?
Hi Samsungvt!
You will have to access the Web Interface of the Paradyne Router to reset it to Factory Defaults.
First, connect your PC to the Paradyne Router. Check your IP address is in the range 192.168.1.xx (xx = any number from 1-254). Open your web browser, type 192.168.1.1 then press enter. Enter the default username and password (shown below) to access the router's web interface. On the left pane, click Erase and Reboot; this will reset the router to factory default.
Default IP address is 192.168.1.1
Default Username and Password: root
Let me know if there's anything else...
Anthony
Jun 21, 2010 | Paradyne (1740A1400) Router
my paradyne has no IP ADDRESS, HOW DO I PROGRAM THE IP ADDRESS INTO WINDOWS 7
start menu
-search programs and files
-run
-cmd - enter
-ipconfig (press enter)
-you'll see defult gateway, thats the ipaddress of you paradyne.
Apr 25, 2010 | Paradyne (6218-A1-200) Wireless Router...
How do I reset the Privilege password on a 2600? The former IT Manager left without telling us what it is, and now we're screwed.
you need a reboot and a serial console I'm afraid. Lots of places on Cisco that detail the password recovery process, it's quite complex so I'm not going to go into detail, but you need to be physically in the same room connected with a serial console cable (9600 baud) for it to work. Basically, use break to interrupt the startup, change the config register to ignore startup config, reboot , go to enable mode, copy run start, enter config mode and reset the password.
Mar 26, 2010 | Paradyne BitStorm 2600 (2611-a1-430)
How does one configure vlan based Quality of Service on Paradyne SDSL Micro dslam
It doesn not appear that the Paradyne SDSL Micro supports QoS (Layer 3):
However, it appears that it can be configured for CoS (Layer 4), even though the device doesnt support CoS itself it can pass that on in the packet header. This also makes sense considering that most DSLAMs hand off straight to an ISP that will use FIFO to deliver the packets to the internet.
Jan 26, 2010 | Computers & Internet
763 people viewed this tip
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
