Tip & How-To about Samsung HL-R6167W 61" HDTV
Error code by led indicator samsung SP67L6HX1X
There are three LED indicators. LAMP, TIMER, STANDBY/TEMP. Each Led or combination leds indicated problem.
  • LAMP blinking : The picture will automatically appear in about 15 seconds.
  • TIMER and STANDBY/TEMP blinking : A cooling fan inside the set is not operating normally.
  • LAMP and STANDBY/TEMP blinking : Lamp cover on the rear of the set is not properly shut.
  • STANDBY/TEMP blinking : Check if the ventilation hole on the rear of the set is blocked, because if the inner temperature is too high, the power will shut off.
  • All LED blinking : Lamp may be defective.
It takes about 30 seconds for the TV to warm up, so normal brightness may not appear immediately. The TV has a fan to keep the inside lamp from overheating. You'll occasionally hear it working.
Samsung HL-R6167W 61" HDTV Logo
yellow blinking light . what does it mean
A blinking yellow for this model indicates the TV is too hot, unplug & allow 30-45 min to cool before re-plugging .
OR: lamp not installed or lamp door not closed. there is a lamp door switch that may not be closing, simulating door not closed
LED Indications
The front panel Status LED provides an indication of
the set's operation and the possible cause of a malfunction.
If an abnormal condition is indicated, perform the
Self Diagnostics procedure.
Self Diagnostics
To activate, press the front panel <ACTIVITY> &<CH
??> buttons at the same time and hold for 5 seconds.
The STATUS LED will then flash denoting a two digit
code.
• The number of flashes indicates the value of the
MSD (tens digit) of the Error Code.
• The flashing then pauses for approximately 1/2
second.
• The LED then flashes indicating the value of the
(ones digit) of the Error Code.
• The Error Code is repeated a total of 5 times.
Example: If the Error Code is "23", the LED
will flash two times, pause, and then flash three
times.
Table 2-2: LED Indications
Error Codes, descriiptions and the most likely cause of
the error are listed in Table 2-3.
Note: The TV must be in "Shut Down." The LED
will probably be indicating an abnormal
condition. If the TV is switched Off, AC is
removed, or a System Reset is performed, the
code automatically resets to "12" No Error.
See the Error Code Log to retrieve a history of
errors.
Note: Use the front panel buttons, not the remote
control.
Note: If there is no response, the front panel may be
locked by a V-Chip setting. To unlock, press
and hold <ACTIVITY> on the front panel for
8 seconds.
LED Indication Condition
Off Off (standby)
Green Power On
Slow Blink Green Power Off with Timer Set
Fast Blink Green (80 seconds) > Off Power Off (Cooling fan still working, 80 sec)
Red Lamp Failure
Yellow TV Too Hot
Slow Blink Red TV May Require Service
Slow Blink Yellow Lamp Door Open or No Lamp Installed
NORMAL INDICATIONS
ABNORMAL INDICATIONS (For details perform Self Diagnostics Procedure.)
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
MY Samsung HLS5679W will not turn on.
It might be the lamp unit which is LED and not a usual type of lamp.
Dec 19, 2012 | Televison & Video
Screen went black you could still hear the tv, timer/standby light is blinking. Is there a projection bulb that goes out. Can this be an easy fix?
U have a LED light indicator said lamp on ur tv?It is blinking?If the LED indicator said lamp is blinking.Than yes,ur projection bulb require changing.Yes replacing bulb pretty easy.
May 01, 2010 | Sony KP-53S70 53" Rear Projection...
3,244 people viewed this tip
Henry  Thomas
Henry Thomas
