Tip & How-To about Computers & Internet
Solutions on IBM Password Reset
We, IBM users, often meet problem with power on password, need IBM password reset or recovery for the OS like Windows 7, Windows XP, Windows Server, etc. What's the most efficient way to reset IBM password for our IBM laptop or desktop computer owners? Whatever the PC is IBM ThinkPad, IBM ThinkCentre IBM NetVista, IBM IdeaCentre or not, we can choose anyone to solve password problem:
1. DIY your own IBM password recovery disk
It is the most efficient and easiest way to help you reset IBM password without reinstalling the system. Take one of the most popular password reset tool - Ainorsoft Windows Password Recovery software as example, 3 quick steps to help us get out of problem:
a. Download Ainorsoft Windows Password Recovery software and burn an .iso image file to a blank CD/DVD/USB Flash Drive from an available PC;
b. Set your target computer to boot from the burned CD/DVD/USB Flash Drive;
c. Remove forgotten IBM password with the burned CD/DVD/USB Flash Drive.
2. Try default Administrator account
We can use default administrator account for IBM password recovery. In IBM Windows XP, 2000, Vista, there is a built-in Administrator user account that is auto generated when we install and without password protected. If we didn't change this Administrator's password, then boot system from Safe mode and login in with the accounts to reset IBM windows password.
3. Access IBM password from other user accounts with administrator rights
If we have another user account which owns administrative privileges, follow the steps below to reset IBM password (take IBM Windows 7 as example):
a. Start computer by pressing F8 key to enter Advanced Boot Options before Windows 7 loading screen appears.
b. Choose Safe Mode at the Advanced Boot Options screen and Enter to login with the accessible admin account.
c. Click Start and input lusrmgr.msc into the Search box.
d. Double-click Local Users and Groups, and then click Users in the Local Users and Groups screen
e. Right-click the account that we will reset its password, and then click Set Password.
f. Input and confirm the new password.
4. Use Ophcrack and Offline NT Password & Registry Editor
They are two common free password recovery tools. We just can have a try with them. Ophcrack can reset passwords no longer than 14 characters using only alphanumeric characters.
With the above four methods on IBM password reset, we, IBM computer users, will be ease once IBM reset password happens to us and needs IBM password removal . Even the IBM rescue and recovery password problem, we can refer to the first solution to help us whatever the OS is Win XP, 7 or others.
Source:
http://windowspasswordrecovery.net/article/ibm-password-reset.html
Computers & Internet Logo
How to do if locked out of Windows 8 laptop?
1. Run "lusrmgr.msc" to reset Dell Windows password.
In Windows 8/7/Vista/XP, there is an easy way to reset a forgotten user account password by just run the lusrmgr.msc. But you need to login your server or laptop with an account which has admin privileges. Note that resetting password with this tip might cause irreversible loss of information for the user account. This data loss will occur the next time the user logs off. You should use this command only if a user has forgotten his or her password and does not have a password reset disk.
Step 1. Start your PC and log on with an available user account which has admin privileges.
Step 2. Click "start" button, press "Win+R" to open "Run box". Type in "lusrmgr.msc" and hit Enter.
Step 3. Local Users and Computers appears, all user accounts of your computer will be list, right-click your user name and select "reset password".
Step 4. Type in a new password and type it again to confirm it, click OK.
After restarting you can login that user account with new password.
2. Remove Dell password by using a Windows password recovery tool.
This is a universal way to reset forgotten Windows password on HP Server or PC, no matter what your Windows system is, Windows 8/7/vista/XP. iSunshare Windows Password Genius is designed to recover Windows password for any kinds of PC, such as hp, dell, acer, Toshiba, Lenovo, IBM etc. It not only can help reset server or laptop password Windows 8, but also Windows 7, Vista, XP and Windows 2000.
Step 1: Download and install Windows Password Genius Advanced on another computer you have access to.
Step 2: Run the software to create a Windows password recovery disk with CD/DVD or USB drive.
Step 3: Insert the Windows password recovery disk to your PC or Server and set the laptop to boot from the disk by changing devices boot order in BIOS SETUP.
Step 4: After boot from the password recovery disk, Windows password recovery tool will start automatically and display a friendly window. Then you can reset whichever account password of your PC or Server by a few clicks.
Windows Password Genius also allows user to create new admin account for your Dell Windows system without logging. With this new user, you can login your Dell computer directly and access control panel to reset other user password.
Jul 29, 2013 | Computers & Internet
200 people viewed this tip
David Payne
David Payne
