Tip & How-To about Cell Phones
How to extend battery life on your cellular phone
A few very easy ways to extend the life of any type of cellular phone.
1. Lower the brightness setting.
The screen (or the display) takes up most of the battery charge. By reducing the brightness, you decrease the power consumption of the entire device.
2. Set the screen to lock, or darken after a short interval of not being used, as apposed to the usually default 30 seconds.
Just like i mentioned above, the screen takes the most power, so why should it be on if you aren't even using the phone?
3. Disable vibration and sound after each button press.
Vibrating the phone, and making noises naturally takes battery, by disabling this, you will get more battery life.
4. Avoid keeping the camera on for long periods of time when not taking photos.
Contrary to what some people may say, the phone is NOT always recording what is on the camera at all times, and is only functional when you enter camera mode, at that time it consumes A LOT of battery power, so you should avoid keeping it in camera mode for long periods of time.
5. Turn off Bluetooth / Wifi unless you are using it.
Bluetooth / Wifi consumes a lot of power when running, it should only be enabled when you are actively using it.
6. Do not play games.
Playing games consumes a lot of battery power. if you don't have a lot of battery and are trying to make that last bar last, you shouldn't be playing games on it.
If your phone is a smartphone, an Iphone or an Android, you can try download or using power saving applications to help manage your battery.
also, make sure to close any background processes to use less power.
Cell Phones Logo
What is the correct way to replace the watch battery?
turn it over and try again. the battery that is
Aug 15, 2015 | Watches
My Toshiba leptop battery runs out and goes from a 100% to 0% after 30-60 minutes. Is there a way to fix this, or it has to be checked by a professional?
Normally when the battry gets to that point the only way to fix it is to get a new battery. If you have had the computer for less than a year the battery may still be under warranty.
Once a battery develops what is called "memory" it is almost impossible to alter. Memory develops over time when the battery is not drained all the way and then allowed to recharge completely. Newer battery designs have preventives for this but still may happen.
Apr 07, 2011 | Toshiba Satellite A300-0CF035 Notebook
i have a problem about adjust brightness on my nokia c3, nokia doesnt support to change it, i think i can get free java application to make it, but i cant find it, could u help me please, thanks
Well I have the same phone as you, I got it 1 month ago. I was realizing the me battery life went down realized the my battery life went really fast. I called my phone server and they said "You can't change the brightness but if you go under settings-themes-select theme-themes-light.nth. That will make our screen darker. Then go under Display-wallpaper-choose a photo that is black and white. It will make your scream darker and will save battery life, plus lower the brightness" hope that helped.
Sep 21, 2010 | Cell Phones
136 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
