Tip & How-To about Computers & Internet
How to use a bluetooth headset for VOIP on Avaya
Sometimes using a wired headset for voip (voice over internet protocol) can really be a pain. The cords are short, you can't move about very far before disturbing the connection and basically you are "chained" to the desk when using one.
Wireless headsets are an option, providing hands free use but they also have their bad points too! The ear covers are large and can get sweaty after long periods of time. Some headsets are bulky and resemble "ear muffs" which limit your hearing in the space around you. Canceling out background noise is a good thing, but it can also be dangerous. Not to mention they weigh a lot when compared to a regular telephone headset.
Ever wish you could use something like the bluetooth from your cell phone to get the best of both worlds? Well, now you can! Even when your computer does not support bluetooth technology.
As long as your computer has a free usb port, enabling bluetooth technology may be as simple as purchasing an adapter from your local department store.
I/O Gear has a bluetooth adapter that works great for this purpose and I bought one for less than $20.00. You buy the adapter, install the software and plug it in to your usb port. When the computer recognizes the adapter, turn on your bluetooth headset and put it into pairing mode. I have a Plantronics Voyager Pro bluetooth headset and all I had to do was press and hold the power button until the red & blue lights began to blink and the pc picked up the signal just fine!
Once you pair your bluetooth with your pc, answering a call using Ayaya is a snap! The adapter provides 300 to 550 feet of wireless reception which gives me plenty of room to move about while using VOIP services. The bluetooth weighs nothing on my ear compared to the larger wireless headsets and the reception using the I/O Gear adapter is wonderful! I answer calls by tapping the tiny button on the bluetooth and hang up using the same motions.
I would reccomend using this method to anyone who works from home using their computer for voice over internet applications.
Computers & Internet Logo
purpose and use of internet application voice-over-internet-protocol
Voice-over-internet-protocol or voip, allows a device(usually a cellular device) to make phone calls over an internet connection(such as home or public Wifi) instead of using the actual cellular connection to make the call. So if you are somewhere your cell phone doesn't get cellular reception, but you can log onto a Wifi network, your phone can still make and recieve phone calls through that Wifi network.
Nov 22, 2017 | Internet Computers & Internet
What is a VOIP connection?
It stands for Voice Over Internet Protocol. Basically your phone system connection is going over the internet. Definition here: http://compnetworking.about.com/cs/voicefaxoverip/g/bldef_voip.htm
k
May 12, 2014 | HP 1040 Plain Paper Inkjet Fax
How do I turn off ECM in my Brother MFC 8220?
From the Brother website:
If you are using Voice Over Internet Protocol (VoIP), (a technology that allows you to make telephone calls using a broadband Internet connection instead of a regular (or analog) phone line, review the information listed below. If you are not using VoIP continue to Step 8.
Voice Over Internet Protocol (VoIP) is not a marketed feature of your Brother machine, however there is a compatibility setting available with this machine that may assist with sending and receiving faxes when using VoIP. Adjusting this setting lowers the baud rate (modem speed) and turns ECM (Error Correction Mode) Off. To adjust this setting follow the steps listed below:
  1. Press Menu or Menu/Set => Fax => Miscellaneous => Compatibility.
  2. Select Basic.
  3. Press OK or Menu/Set. (For touchscreen models, skip this step.)
  4. Press Stop/Exit.
Jan 07, 2011 | Brother MFC-8220 Fax
all of a sudden I am not able to hear people - they can hear me. This is intermittent.
First, Hello! Second.
VOIP means Voice over IP, naturally VOIP is a realtime communication and there fore is prone to error. Let me explain in more detail.
TCP/IP (Transfer Control Protocol/Internet Protocol) uses two communnication protocols, TCP(Transfer Control Protocol) and UDP (User Datagram Protocol).
The TCP uses sequencing and acknowledment in order to start the connection, transfer data, acknowledge data arrives in order to send the subsequent data segment. In order word is like mail delivery with confirmation.
The UDP is like besto effort delivery. "I sent the data and hope you get it". Because the data travel many different ways in many Packets TCP send the data, but on destination arrives the segments in different order, The TCP puts them together, on realtime it will imposible to understand the other party in this way. So, this is why you sometimes you see squares or "error" on video streaming, because video is in real time, if you have to wait for all the packet to get toghether take toooooo much time.
So you have to check for Qos or resuce you transfers over internet while sepaking. On Wikipedia are very good info on Qos. Theres router with Qos integrated to ensure some bandwith is dedicated to VOIP transmissions. I Hope It Helps! Good Day!
Jul 02, 2009 | Hitachi WIP-5000 IP Wireless Phone
173 people viewed this tip
David Payne
David Payne
