Tip & How-To about Computers & Internet
How to make bootable USB Flash Drive with puppy linux installed on it
Hello!Almost everyone has problems with booting up. Sometime we have some valuable information on our hard drive and we can't boot up, can't start windows and can't transfer our files. There comes question: Can I somehow save my files in safe place? What can I do?One of the easiest way to solve this problem is to create USB Bootable Flash Drive. So we can boot up. then we have to transfer files from our corrupted hard drive to USB Flash Drive.
All you need is:1) USB Flash Drive2) Health (other pc) running on windows3) Software
So let's start!START HEALTH PC.First of all you have to download same small linux distribution. Puppy linux is excellent for this job. And it's FREE, simple, and exremally SMALL. You can Download Puppy linux from the following link:http://puppylinux.org/main/Download%20Latest%20Release.htmNote: When I wrote tutorial latest version of puppy was 5.2.0. But don't panic if our version differs from the 5.2.0. The principe of installing is Same
After downloading we have to download software to make USB Flash Drive bootable and to install Puppy Linux on USB. This software is UnetBootIn(Universal NetBoot Installer). You can download it from here:http://unetbootin.sourceforge.net/unetbootin-windows-latest.exe
Plug in your USB.Now start UnetBootIn.Take a look at picture below:
Note that Drive letter Is the letter for USB you plugged in. For checking go to My computer.
And click OK
wait a while and you are done when it asks for rebooting click Exit. rebooting isn't necessary.
FOR DOWNLOADING AND INSATALLING PUPPY ON USB WE USE HEALTH PC.
Now plug usb in corrupted PC and start the corrupted PC.When it starts, immediatelly press repeatedly ESC for (for asus EEE PC), F8(for some other computers) or F12. Try these keys. Then there comes window that askes you to select bootable device. Choose your USB.then there will come up Puppy Linux boot manager. Don't press anything let's see if puppy starts aotomatically, If not, restart pc, repeat the procedures above and when Puppy boot manager comes up press F3.Then type text below and press Enter:"puppy PMEDIA=usbflash" (or "puppy PMEDIA=usbhd" for USB Hard Drive).And puppy linux will start.NOTE: if it asks about language and time zone, also resolution select with your mind, but make sure that 22" LCD monitor resolution isn't too small(800X600)!)
Now browse for files you want copy them to USB by Drag and Drop method and you are DONE! Now your info is in safe place.
Thank ou for viewing my tutorial.
Computers & Internet Logo
starting up i get PXE-E61 media test failure some people tell me its the hard drive some say the cddrve others say it could be trying to boot from a LAN
PXe Boot is used by the computer to boot to a network DOS-type environment.If you are receiving a PXe failure message on bootup check that your PC is set to boot from the CD Rom, Floppy, and Hard Drive BEFORE network or other boot device.
That's where you need to check to get solution to your problem, if not... try these
1. your settings in your bios
2. faulty cable/wire to your media device (hard drive, cd/dvd rom, etc)
3. The cmos battery (which indirectly points to your bios settings)
Hope this helps!
Jul 18, 2011 | Toshiba Satellite L455D-S5976 Notebook
hello my problem is in the boot of the computer when i turn it on it apears a black screen said : operating system not found the labtop is toshiba
If you have a restore disk place it in the ROM and then do as it says to do when booting it up this would be the last resort try these suggestions below first. Also you can go back to an earlier time and try to go that route if this does not work you will need to re-install original software. I hope that you saved your important files. Also go to the BIOS press F2 key when boot screen appears and try making your boot configuration to boot from the hard drive as the first boot it may not be recognizing the ROM drive on the boot up. Go to the boot section of the BIOS. Sometimes when going to the hard drive first boot as the option it will open Windows. Also you can do a system repair insert the operating disk and when it loads choose repair. Follow the on screen instructions.
Also you can press F8 at the boot screen and go to "Safe Mode" go to run and type in msconfig then go to restore once there go to restore from an earlier time. Try this out these options are basic troubleshooting process's we all use to get out systems up and running again others that are reading these notes please copy this information it can save a hassle of having to re-install and loosed valuable information, I hope that assist you.
Jan 22, 2011 | Toshiba Satellite A105 Notebook
Acer says this when i sign-on: Windows could not start because of a disk hardware configuration problem. Could not read from the selected boot disk. Check boot path and disk hardware. Please check the windows documentation about hardware disk configuration and your hardware reference manuals for additional information. What does this all means..
It's not able to see your hard drive. Something may have changed in CMOS about the boot order. You should enter the bios and see if it sees your hard drive. Then go into advanced boot options. First boot object is usually set to CD Rom for setting up operating systems and the second boot device should be your hard drive. Third boot option can be left at none or a floppy drive if you have one. If the bios is seeing your hard drive and it is set as a boot option then the drive may be damaged or system files have been lost. If there are valuable files on the hard drive and it is failing then you might consider taking this to a professional and trying to rescue your files asap before the drive deteriorates any more than it is. You can also try some repair options from booting off the Window's CD but beware that formating your drive is one of the options and this will erase any files you have on the drive.
Nov 19, 2009 | Acer Aspire One Netbook 8.9" Notebook
My western digital external HDD 650GB freeze my computer during boot up
These drives are too complicated and they die like crazy.
It sounds like it's fairly new so you shouldn't have problems with RMA.
You are lucky you didn't have any valuable data on it...
Oct 27, 2008 | Western Digital My Book Essential Edition...
615 people viewed this tip
David Payne
David Payne
