Tip & How-To about Computers & Internet
Create Windows XP Password Reset Disk
Did you forget your Windows XP User password? You can click the "?" button to see your password hint.Or you can use your password reset disk. This article describes how to create a password reset disk for a computer that is not a member of a domain in Microsoft Windows XP.(that is part of a workgroup, or that is not connected to a network.)
What is the Windows XP Password Reset Disk?Do you need to enter a password when booting into Windows XP Pro? Afraid you might forget this password down the road and not be able to run your PC? Make a password reset disk to protect against a lost password.
Note: You may want to know how to create a user login password to protect xp.
To protect user accounts in the event that the user forgets the password, every local user should make a password reset disk and keep it in a safe place. Then, if the user forgets his or her password, the password can be reset using the password reset disk and the user is able to access the local user account again.
The Forgotten Password Wizard lets you create a XP password reset disk that you can use to recover your user account and personalized computer settings if you forget your password.
How to create a XP password reset diskTo create a password reset disk for your local user account, use the following method.
RequirementsThe following methods require a floppy disk drive and a blank floppy disk. As we all know, the floppy disk is easily damagedand it is out of date. In this demonstration, I will use a blank USB Fash Disk instead of floppy disk. Firstly make sure it is connected with your computer.
1. Click Start, and then click Control Panel.
2. In Control Panel, click User Accounts.
Note: If you're viewing the Classic View of Control Panel, double-click on the User Accounts icon.
3. In the User Accounts pane, click the account that you want to work with. Here I will click my account name "Andy".
4. Under the Related Tasks left side options, click Prevent a forgotten password to start the Forgotten Password Wizard, and then click Next.
5. In the drop-down menu, there are 2 options for us to choose. One is Floppy A, another is WPKEY (It is the name of my USB Flash Drive). Select the WPKEY and then click Next.
6. In the Current User Account Password box, type Andy's password , and then click Next. The Forgotten Password Wizard will start creating the disk.
Note: If the user account does not have a password, just leave it blank in the Current user account password box.
7. When the progress indicator shows 100% complete, click Next and then click Finish in the next window.
The password reset disk contains only one file called userkey.psw, which is an encrypted version of your password.
Finally Label the disk "Windows XP Password Reset" and store it in a safe place. You can use the password reset disk to gain access to your Windows XP-based computer if you forget your password.
Tips:
1.
You only need to create a password reset disk for your Windows XP logon password once. No matter how many times you change your password, this disk will always allow you to create a new one.
2. Keep in mind that anyone who possesses this disk will be able to access your account at any time, even if you change your password.You'd better store it in a safe place.
3. Not a Windows XP user? See the guides for other Windows versions.
How to Create a Windows 7 Password Reset Disk?
How to Create a Vista Password Reset Disk?
4. Unfortunately, if you've forgotten your Windows XP password and can no longer acceses Windows, you won't be able to create a password reset disk. Luckily there is a Windows password recovery program which can help you to find lost password. It is popular way of getting your password back, even you don't have a password reset disk. You can download the free tried Demo on clicking below link.
Windows XP Password Recovery Program [Safe Download]
Computers & Internet Logo
Lost password on Windows XP Computer
You can log on to the computer by using a password reset disk, follow these steps.
  1. Restart the computer.
  2. On the Windows XP logon screen, click the user name that you want to use, and then press ENTER.
Note You receive the following error message: Did you forget your password? You can click the "?" button to see your password hint. Or you can use your password reset disk. Please type your password again. Be sure to use the correct uppercase and lowercase letters.
  1. Click Use your password reset disk. The Password Reset Wizard starts. The Password Reset Wizard enables you to create a new password for your user account.
  2. In the Password Reset Wizard dialog box, click Next.
  3. Insert the password reset disc into the CD drive, and then click Next.
  4. Type a new password in the Type a new password box, and then type the password again in the Type the password again to confirm box.
  5. In the Type a new password hint box, type a hint for the password, and then click Next.
  6. Click Finish, and then try to log on to Windows XP again.
If you were able to reset your password and are now able to log on successfully, you have resolved the issue, and you are finished.
Regards,
Riztech
Apr 11, 2010 | HP Vectra Xe320 PC Desktop
Forgot username for admin acc in windows xp
Forgetting your Windows administrator login password. With no way to get into the system, you can’t even perform basic maintenance, let alone a thorough tune-up. Formatting is always an option, but we consider that a last resort. (Plus, guess who’s going to have to help reinstall all the programs lost after a wipe?) But all hope is not lost. There are a few ways to actually retrieve a lost Windows account password. Read on, and we’ll show you the light.
1st Method:
The first thing which you check if you forget login password. When we install Windows, it automatically creates an account "Administrator" and sets its password to blank. So if you have forget your user account password then try this:
Start system and when you see Windows Welcome screen / Login screen, press ctrl+alt+del keys twice and it'll show Classic Login box. Now type "Administrator" (without quotes) in Username and leave Password field blank. Now press Enter and you should be able to log in Windows.
Now you can reset your account password from "Control Panel -> User Accounts".
Same thing can be done using Safe Mode. In Safe Mode Windows will show this in-built Administrator account in Login screen.
2th Method:
There are a lot of Windows password revealers and crackers available, but we’ve found that Windows Password Recovery Tool is the most effective.:
Windows Password Recovery Tool is one of the easiest password recovery tools to use. It allows you to reset a user account password, including the Administrator password. It is also a relatively small download.
Windows Password Recovery Tool Service: http://www.windowspasswordsrecovery.com
May 07, 2008 | Dell Inspiron 6400 Notebook
211 people viewed this tip
David Payne
David Payne
