Tip & How-To about Office Equipment & Supplies
Canon Service Error 5202
Service Error 5202 solution for ip1800 / ip1900
Steps:
1. turn-on printer, still blinking and a error message on screen, open cover.
2. While printer cover is open, unplug the power cord at the back. Of course it
turns off.
3. Remove all cartridges, clean the contact points and then insert them back
properly. Move the entire cartridge to its parking area.
4. Close the printer's cover, plug the power source, turn the printer on.
5. It should be working fine now. Mabuhay!!!
Error 5202 whaT SHOULD I D0
Error 5202 means: UNRECOVERABLE ERROR. You need to return your printer to where you bought it and replace a new one if it is still under warranty.
Jul 20, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
how to open canon ip1900 coverings
Remove the paper and cartridges.
With the printer facing you, open the cover and remove the 2 screws you can see extreme left and right. These are the only screws needed to remove the covers.
Now turn the printer upside down and look for 2 arrows on the left and right side of the printer. Stil a screwdriver up where they point to to undo the catches. Now shove the two side panels backwards from the printer.
To release the remaining top panel and lid, pull it off its plastic catches.
Apr 19, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
how to fix service error on canon ip1800
You will need a resetter. Download this software and follow these steps.
Step 1: Reset hardware
  1. Press Resume button hold for 1 – 2 minutes
  2. Open the cover
  3. Release the catridge and then put catridge again
  4. Close The Cover
  5. Turn Off
  6. then Turn On again
Step 2: Reset Software using general tools
  • Download software resetter or general tools for canon pixma iP1800 http://www.mediafire.com/?nmfns4hixel :Driver should have been install correcly.
  • Connect USB cable.
  • Before connect power, press and hold power button then connect the power.
  • At the same time Hold power button, and press reject button for 2 times then release power button.
  • Run software resetter for canon iP1880.
  • Don’t forget to open lock release in the software. ( note : to view locK release menu, min resolution 1024 x 728)
  • Then select Set Destination to iP1880
  • Check CLEANING and EEPROM CLEAR
  • Click MAIN and PLATEN
  • Finally test print by click TEST PATTERN1.
Mar 18, 2010 | Office Equipment & Supplies
Canon iP1800-alternating flashing lights. 1 long green, 3 short orange. How do i troubleshoot this? It is a ''Service Error 6000''. Which translates to a paper jam, however, there is no paper in the printer. Help?
1- Please open the cover and inspect the inside of the printer carefully. There might be a little piece of paper or a tiny object jammed in there and is causing this error message. Also get some canned air and clean the inside of the printer. 2- Restart the printer.
Feb 12, 2010 | Canon PIXMA iP1800 Printer
canon ip1880 printer service error 5202
Sep 30, 2008 | Office Equipment & Supplies
4,246 people viewed this tip
k24674
jasbo
jasbo
