Tip & How-To about Refrigerators
Finding Your Model number on Older GE Refrigerator (Frige)
If it is a side by side look in the frige side on the side walls near the bottom.
Also check the bottom right side of the frige between the door and the base.
Refrigerators Logo
Unable to locate water filter cartridge
http://www.searspartsdirect.com/partsdirect/part-model/Whirlpool-Parts/Refrigerator-Parts/Model-GD2SHAXLQ00/1198/0165000/W0205059/00001?blt=06&prst=&shdMod=
it says the filter is down on the bottom just like in this diagram,the model number you sent isn't the full number,if you open the fridge door and look on the right hand wall up near the ceiling there should be a tag there with the full model number,if it's an older unit it could be down near the bottom fridge door hinge,send the number back and i can check it for you.
Jul 20, 2013 | Whirlpool Gold White-on-White 21.9 cu. ft....
My friend has a side by side refrigerator. The freezer side works great but the refrigerator side doesn't keep anything very cold. Any suggestions? She doesn't know what brand it is. It has an H on it and says profile.
evaporator is frozen up or fan is not running in freezer to fix you may have to replace heating element or defrost timer or fan motor or defrost terminator
Sep 26, 2010 | Refrigerators
I have a side by side refrigerator and the freezer is not cooling, what do you think the problem is?
if the refigerator and the freezer are warm,i'd have to say you have a bad computer board,they go on the ge's all the time,let me know if there's ice on the back wall inside the freezer or is it warm in both sides,also send the model number,it should be on the right side wall in the fridge up near the ceiling or if it's older it could be down near the bottom hindge on the fridge door
Sep 01, 2010 | GE Refrigerators
Freezer side cold, frige side warm
Defrost heater is open behind back wall. order new heater #wr55x10101 remove 4 screws 2 bottom, 2 top behind light shield, defrost freezer so ice is off of evap, replace heater with new one.
Nov 13, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool Ice Magic-No Frost Refrigerator (I'm guessing 30 years old)
look above the bottom kick plate, on the right middle, or inside the fresh food interior walls been a long time to remember this sweety machine loved it too everything where it was needed to be
Jun 23, 2008 | Whirlpool Refrigerators
557 people viewed this tip
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
