Tip & How-To about Computers & Internet
How to Boot From A Windows 7 Password Reset Disk?
Forgot Windows 7 password? It seems to be a universal iusse as widespread of Windows 7. To solve this problem, you can either buy a burned Windows password recovery CD on-line or burn such a password recovery disk withWindows 7 password reset software. But no matter which method you choose, you have to boot your locked computer from the password recovery disk. However, you will feel frustrated when you have little computer skill. Take these 2 methods as your reference when you encounter the similar problem.
Of course, firstly , you need to create a Windows 7 password reset disk, and then pay attention on how to boot from the Windows password reset disk .
Method OneInsert a burned Windows 7 password recovery CD in your locked computer boot the locked computer from the CD/DVD as follows:
  • 1. Turn on or restart the locked computer, watch the screen for a message like "Press to http://www.passwordunlocker.enter SETUP "or something similar. Press this key as soon as you see the message to enter BIOS menu.
  • Note: The key pressed to enter BIOS is different based on manufacturers, but F2 or Delete are the most common keys
  • 2. Use arrows to choose Boot on the taskbar, select Boot Device Priority and press Enter.
  • 3. Set CD ROM to the first boot device according to the prompts on the right.
  • 4. Press F10 to save and exit BIOS. You computer will restart with the changed BIOS settings
Method Two
If the method above doesn't work, you can also try to enter Boot Menu to boot the locked computer from the burned CD/DVD as follows:
  • 1. Insert a Windows 7 password recovery CD in your locked computer.
  • 2. Start the locked computer and immediately tap and keep tapping F8, ESC or other keys until the Boot Menu screen appears.
  • 3. Select CD ROM as the first boot device and press Enter. After that, your computer will restart with changed bios settings.
PC users can not only set bios password for computer, but also set Windows logon password. If the BIOS is password protected, you need to clear or remove the BIOS password before you can enter BIOS to change boot order.
By the way, if you forgot Windows 7 password or Windows 7 password-protected, it is suggested to take Windows password recovery software to create a Windows password reset disk. Take Windows Password Unlocker for example, it takes you only 4 steps to burn a bootable CD/DVD or USB flash drive for Windows 7 password recovery in 5 minutes.
Step 1: Download and install Windows Password Unlocker Professional in any availble PC
Step 2: Burn a Windows 7 Password Recovery CD/DVD or USB flash drive.
Step 3: Boot from the burned the Password Recovery CD/DVD or USB flash drive.
Step 4: Reset Windows 7 password under Windows PE.
Computers & Internet Logo
Forgot windows 7 password on my asus 1025ce notebook
How to unlock Windows 7 password when you forgot windows 7 password? Try to make use of SmartKey Windows Password Recovery. How to unlock Windows 7 password when you forgot windows 7 password? Try to make use of SmartKey Windows Password Recovery.
Jan 05, 2013 | Computers & Internet
Forgot Sony Vaio password
I met the same difficulty for the previous period,and I know the easy an effive method that you can use Windows Password Reset to solve it by the Internet,while the use method is following.
Tip1:Download Windows Password Reset from http://www.windowspasswordreset.net and install it on other unlocked computer.
Tip2:Burn Windows Password Reset to CD/DVD or USB.
Tip3:Insert newly created CD/DVD or USB to your computer which you forgot its password and reboot it,and follow the instruction that follows.
I hope it can help you soon.
Jul 25, 2012 | Sony Computers & Internet
i forgot my password
http://www.passwordseeker.com. Itcan reset almost all Windows passwords in seconds. It also compatible with windows7.
Feb 28, 2010 | AccessData Password Recovery Tool Kit (ftk...
200 people viewed this tip
David Payne
David Payne
