Tip & How-To about Microsoft Xbox 360 Console
How to completely dissasemble an Xbox 360
BEFORE YOU READ THIS TIP: Opening an Xbox 360 console will void any type of warranty you may have. FixYa.com and I are not responsible for any damages you may inflict on your Xbox 360 console.
The tools you will need:
1. A clean, flat working surface
2. Xbox 360 Opening tool
This isn't 100% necessary. But it makes things a whole lot easier. They're about $5 on Ebay.
3. A Torx 8 and a Torx 10 screwdriver/bit
4. A flathead screwdriver
5. A flathead precision screwdriver
6. And of course, an Xbox 360
Removing the Xbox 360 case
1. First, remove the Xbox 360 faceplate. On the bottom of the Xbox, (right side if your Xbox is horizontal), towards the front, you will see a little notch.
Slide a fingernail in there and gently pull up.
The faceplate should come off with minimal force.
2. Next, you must remove the grey grills on both the top and bottom of the Xbox. (Right and left if your Xbox is horizontal). First, lets remove the top one. (The one the hard drive plugs into). If you look through the little exhaust holes near the top of the Xbox, you will see 3 little tabs on each side holding the grill in place.
Each tab must me unhooked by poking it with a screw driver. The ones towards the front are a little difficult. There are 2 gaps in the top grill that you must slide the screw driver into.
Get the screw driver in between the tab and the white outer case and gently pull the tab away. Towards the other side. At the same time, pull the grill up to unhook the tab. Do the same for the opposite side.
The other 4 tabs, (2 on each side), are much easier. Simply poke the screwdriver through the exhaust holes to push the tabs away from the hooks. Gently pull up on the grill at the same time.
One tab will be covered by a little rubber footie. Just pry the footie up with a finger nail to expose a hole. Poke the screwdriver through that hole.
After you've unhooked all 6 tabs, the grill should easily lift off the Xbox.
Now, for the other grill on the bottom do the same thing. Again, there are 3 tabs on each side. These tabs just have to be poked through the exhaust holes. No need to remove any rubber footie.
3. Now that both grills are off, it's time to remove the main case. If you look on the back of the Xbox, you will see a total of 7 slots. 5 on the right, and 2 on the left.
Take your Xbox 360 opening tool and slide 5 tabs on the right into the 5 slots on the right of the Xbox.
Push with your thumbs to release the locks holding the 2 halves together.
Now do the same with the left side. Only this time, use the side of the opening tool that has the 2 tabs.
*NOTE: The above can also be accomplished without the opening tool. Use a small, flat head precision screwdriver. With one hand push the 2 halves away from each other while carefully sliding the screwdriver into each slot individually.
Now look on the front of the Xbox and you will see 4 locks.
Simply slide a flathead screwdriver under the tab to release each lock. Being careful not to snap off the tabs.
Now lay the Xbox upside down and pull the bottom half of the case off.
To get the top half of the case off, you must use your Torx 10 screwdriver/bit and remove these 6 screws:
Then look on the front of the Xbox at the eject button. Pull the eject button off by grabbing it towards the middle and pulling straight out.
Now, CAREFULLY flip the Xbox back over so its right-side-up and pull off the top half of the case.
Removing the DVD Drive:
1. Removing the DVD drive is quite easy. Simply unplug both cables from the back of the drive. And carefully lift the drive straight out.
Removing the Fan Shroud:
1. Removing the fan shroud is also very simple. Just use a small flathead screwdriver to pry open the clip connecting it to the fan. Then lift it straight out.
Removing the fan:
1. first, you must unplug the fan.
2. To actually remove the fan you must lift up on the upper metal lip and tip the fan out.
3. Now, being very careful of the tall capacitors in front of the fan, pull the fan out.
Removing the RF Module:
1. First you must pop off the plastic cover. Do this by using your fingers and pulling the top part off the circuit board. Be very careful.
2. Now remove all 3 screws with your Torx 8 Screwdriver.
3. Now carefully pull the RF Module straight out.
Removing the Motherboard:
The Motherboard is the main component of an Xbox 360. Be very careful!
1. Flip the Xbox upside down and take out the remaining screws. There should be 8 small black screws in the middle and 10 brass screws. The black ones use Torx 8 and the brass ones use Torx 10.
2. Now slide your fingers into the DVD drive slot and keep the motherboard from moving while you flip the Xbox back over.
3. Now carefully grab the taller heatsink and pull the mother board out by tipping the front out first, then the back.
4. Place the motherboard down carefully.
Congratulations! Your Xbox 360 is now full disassembled!
Microsoft Xbox 360 Console Logo
mi xbox 260 wont let me play madden11 becuz it always says mixed media player
Your disk is too scratched up or the laser lens is dirty. you can try to wash your Game with water and light soap or have it buffed. if that doses not work try to clean the laser lens with a lens cleaning disk or clean it with some alcohol and a q tip (requires opening your Xbox 360 or 260 in your case lol.) doing this could void your warranty (If you use a hair dryer you can get past the warranty seal with out breaking it)
Dec 30, 2010 | Microsoft Xbox 360 Console
xbox 360 will not read disc
You need to either clean the laser or replace the dvd-rom drive.
Both of these cases involve opening up the console and voiding any warranty Microsoft offer.
First you need to determine if its not reading a certain type of disc, or not reading any disc at all, if iys not reading any disc at all, it may have grime or dirt on the laser causing the problem.
You can clean the laser with a clean cue-tip or cotton swab, by opening the console, removing the dvd-rom drive and then opening the dvd-rom drive case to expose the laser.
If after cleaning the laser it still does not read discs, you need to replace the dvd-rom drive. I hope this helps. Good luck.
Sep 03, 2010 | Microsoft Xbox 360 Console
xbox won't read my disk
try a music cd, movie dvd, game disc.
which ones do not work?
if it will not play just one type or only 1 game i woudl check the game itself. if it will not play say games or dvds but will play cds then your laser needs calibreation.
here is a link to explain this.
http://www.fixya.com/support/r4192169-fix_calibration_cd_dvd_drive_no_disc
doign this on the xbox will void warranty if there is any but also requires special tools for proper disassembly soyou don't damage the case.
Jun 03, 2010 | Microsoft Xbox 360 Console
disc reading problem
use a disc based lens cleaner. opening your xbox console will void your warranty.
Aug 20, 2009 | Microsoft Xbox 360 Console
2,728 people viewed this tip
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
