Tip & How-To about Video Game Consoles & Games
Here are 2 ways to connect your PlayStation 3 to the Internet; using a
wired (Ethernet) connection or through a wireless connection.
1. Wired Connection
1. Make sure that your PlayStation 3 is connected to a broadband-enabled network using an Ethernet cable.
2. Click Settings in the Home menu, then Network Settings.
3. Click Internet Connection Settings . Then press the button.
4. A message will pop up saying that you will be disconnected from the Internet. Choose Yes. Then press the button.
5. When you are given the choice of connection methods choose Wired Connection.
6. Choose Easy - the basic settings are automatically set.
7. Now click Save.
8. If you want to you can now test your wired connection by clicking Test Connection.
Your PlayStation 3 will now try and connect to the Internet. If the
connection isn't successful you should follow the instructions which
will appear, to check your settings.
2. Wireless Connection
1. Click Settings in the Home menu, then Network Settings.
2. Click Internet Connection Settings . Then press the button.
3. A message will pop up saying that you will be disconnected from the Internet. Choose Yes. Then press the button.
4. When you are given the choice of connection methods choose Wireless Connection.
5. Now choose Scan. Your PlayStation 3 will now search for any available access points and show these in a list.
Note: Some PlayStation 3 models have an 'Automatic' option, which if
followed will complete the required settings for you automatically.
Simply click on Automatic if the access point you are using supports automatic setup.
6. From the list of access points choose one which you'd like to use.
7. Check the SSID for the access point, press the right button. If
you don't know what the SSID is then you should contact the person who
setup or runs the access point for more information.
8. Select the security method necessary, press the right button.
9. Enter the encryption key. This will be shown as a series of
asterisks (*). If you don't know what the encryption key is you should
contact the person who setup or runs the access point for more
information.
10. Now press the right button.
11. Choose either Easy or Custom and adjust the settings.
