Tip & How-To about Microsoft Windows Server 2003 Enterprise Edition x64 for PC
VPN in Microsoft Server 2003
The full form of VPN is Virtual Private Network. VPN gives extremely secure connections between private networks linked through the Internet. It allows remote computers to act as though they were on the same secure, local network. Allows you to be at home and access your company's computers in the same way as if you were sitting at work.
Almost impossible for someone to tap or interfere with data in the VPN tunnel. If you have VPN client software on a laptop, you can connect to your company from anywhere in the world. VPN goes between a computer and a network (client-to-server), or a LAN and a network using two routers (server-to-server). Each end of the connection is a VPN "endpoint", the connection between them is a "VPN tunnel".
When one end is a client, it means that computer is running VPN client software. You can use a virtual private network (VPN) to connect components to one network by using another network. VPN do this by "tunneling" through the Internet or another public network. With a VPN, connections across the public network can transfer data by using the routing infrastructure of the Internet, but to the user, the data seems to travel over a dedicated private link.
A VPN gives you the benefit of a dial-up connection to a dial-up server, plus the flexibility of an Internet connection. Using an Internet connection you can connect to resources all over the world. If you have a high-speed Internet connection at your computer and at your office, you can communicate with your office at full Internet speed. This is much faster than any dial-up connection that uses an analog modem.
VPNs use authenticated links to make sure that only authorized users can connect to your network, and they use encryption to make sure that others cannot intercept and cannot use data over the Internet. A Tunneling Protocol is a technology that helps make the transfer of information over the Internet more secure from one computer to another.
VPN technology also permits a corporation to connect to its branch offices or to other companies over a public network, such as the Internet, while helping to maintain secure communications. The VPN connection across the Internet logically operates as a dedicated wide area network (WAN) link.
VPN in Windows 2003 Server: You need a high speed Internet connection to configure and run VPN server. Two individual lan card must be present in a single system where you want to configure a VPN Server. The lan cards should ping each other. Also need a User which's Dial in allow access should be enable. Microsoft 2003 server two tunnelling protocols for a secure VPN connection, one is PPTP (Point-to-Point Tunnelling Protocol) which Provides data encryption using Microsoft Point-to-Point Encryption. The other is L2TP (Layer Two Tunnelling Protocol) which Provides data encryption, authentication, and integrity using IPSec.
Steps to create VPN Server in 2003 Server: At first I go to Start and point to Administrative Tools, then click Routing and Remote Access. Then I click the server icon that matches the local server name in the left panel of the console. If the Routing and Remote Access service was previously turn on, you may want to reconfigure the server.
To reconfigure the server Right-click the server object, and then click Disable Routing and Remote Access. Click yes to continue when you are prompted with an informational message. Then Right-click the server icon and then click configure and Enable Routing and Remote Access to start the Routing and Remote Access Server Setup Wizard. After that click Remote access (dial-up or VPN) to turn on remote computers to dial in or connect to this network through the Internet. Then I have Click to select VPN. In the VPN Connection window I click the network interface (Lan) which is connected to the Internet and go the IP Address Assignment window, then I click Automatically because there was present a DHCP server in network. However, if DHCP is not available, you must specify a range of static addresses.
If you use from a specified range of addresses, open the Address Range Assignment dialog box and Type the first IP address in the range of addresses that you want to use in the Start IP address box. Type the last IP address in the range in the End IP address box. Windows calculates the number of addresses automatically. After that I have accept the default setting of No, use Routing and Remote Access to authenticate connection request and finally Click Finish to turn on the Routing and Remote Access service and to configure the server as a Remote Access server.
For the remote access server to forward traffic properly inside your network, you must configure it as a router with either static routes or routing protocols, so that all of the locations in the intranet are reachable from the remote access server. It also need for security purpose.
Microsoft Windows Server 2003 Enterprise Edition x64 for PC Logo
what is vpn server
Point-To-Point Tunneling Protocol (PPTP) is another tunneling protocol used to connect a remote client to a private server over the Internet. PPTP is one of the most widely used VPN protocols because of it's straightforward configuration and maintenance and also because it is included with the Windows operating system.
http://electronicshelponline.blogspot.com/ A VPN or Virtual Private Network is a method used to add security and privacy to private and public networks, like WiFi Hotspots and the Internet. VPNs are most often used by corporations to protect sensitive data.
Oct 25, 2016 | Computers & Internet
what's happen to my ps 3? have error d5027
That error basically means your network connection to the PS3 network servers is unstable. Given the time of year and the number of kids that have snow days and are at home, and parents staying home working across the internet, the most likely cause is simple network congestion. You should notice this issue go away early morning when fewer people are online, and get worse as the day progresses. In some cases, you can set up a VPN or Virtual Private Network connection that can help. If you want to try that, go to this link http://community.us.playstation.com/t5/PlayStation-Home-Support/Using-Virtual-Private-Network-VPN-To-Defeat-Network-Error-D50027/td-p/44868077 for instructions on setting it up.
Jan 08, 2015 | Video Game Consoles & Games
How to configure Remote access/VPN server role (using windows as my operating system)?
You can configure a server that allows remote users to access resources on your private network over dial-up or virtual private network (VPN) connections. This type of server is called a remote access/VPN server. Remote access/VPN servers can also provide network address translation (NAT). With NAT, the computers on your private network can share a single connection to the Internet. You can find a step by step guide here:http://technet.microsoft.com/en-us/library/cc736357(WS.10).aspx
Aug 15, 2010 | Belkin Computers & Internet
un block blocked web sites my space facebook and any blocked web sites on a government computer
Total Internet Privacy and the TIP Tunnel offer complete Private Internet Browsing,Private Internet Service, Anonymous Surfing, Anonymous Internet, web surfing through the webs best most secure and private web tunnel, with free private internet browsing tools. TIP is a complete encrypted VPN solution for private internet communications.
Tiptunnel is designed for individuals accessing the Internet from insecure Internet connections, such as wireless, or from countries with restrictive Internet filtering systems.
Anonymous Internet surfing by default simply doesn't happen but it is possible. The most basic way of protecting your identity is to use an anonymous VPN to hide your IP address when you are surfing. Your communications can still be intercepted as the majority of that web traffic is in the clear but it's less likely unless someone is deliberately targeting you, the main benefit is that your IP address is not left in the logs of the web servers and your web browsing will remain more private.
provides a secure, obscured VPN tunnel between your computer and our secure servers located in Asia or the US and the Europe.
TIP Tunnel Enterprise package includes:
* Anonymous surfing
* IP Address Obscurity, your real IP address is hidden
* Bypass Internet filtering by your ISP
* All traffic is 100% encrypted with AES 256 bit encryption
* Immune to packet sniffing, attacks and popups
* Real-time virus protection
* Real-time spam filtering
* Guaranteed 100% privacy with no logs
* Supported platforms include Windows, Linux and Mac
* Multiple server access worldwide
* Professional 24/7 Technical Support
http://tiptunnel.com
Jan 06, 2010 | Computer Associates Full Version ...
DLink DI-624s - can't get Cisco VPN Client to connect.
The "Virtual Server" setting is designed to give the general public access to a network resrouce (web/ftp/media server) on your internal network. If your the VPN concentrator is external to your network (meaning you'll have to use the internet to connect to it), then you won't need to define a virtual server on the DI-624.
You'll just need to enable the IPSEC and PPTP VPN Passthrough which it sounds like you've already done this. I've run into some ISP's that block VPN connections out of their network. If you have the ability, try to directly connect your laptop into your cable/DSL modem in place of your router and see if you can make a VPN connection, if not contact your ISP, if you can then verify you enabled the VPN passthroughs because your router is blocking them.
GIve it a shot and let us know your results.
Apr 26, 2008 | D-Link AirPlus Xtreme G DI-624 Wireless...
1,364 people viewed this tip
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
