Tip & How-To about Video Game Consoles & Games
How to connect to internet using your Sony PSP
1) go all the way along left untill you reach settings
2) go down your settings list untill you find network settings (at bottom of list)
3)press X to enter
4)click on infastructure mode
5)click new connection
6) scan . . . .
7)it should find your hub/connection point
8)click on you access point
9)press right (d-pad) twice
10)enter your network key (usually on bottom or back of your access point/hub making sure you puts caps when necessary)
11)press right (d-pad) another 4 times after entering key
12)should say "Press the X button to save settings"
13)so press X
14)then X agian to test connection
15)ok, so far so good?
16)if not try re entering key following from steps 1 again
17)if ok, press O twice to bring you back tou your menu
18)go along to internet browser and press X to open it
19)it will aoutomatically use your network settings you have just entered and open up google or the psp online website
20) your all ready to browse the net on your PSP
Video Game Consoles & Games Logo
I don't know how to use my Internet?
ok. very easy.
3)press X to enter
6) scan . . . .
13)so press X
please vote my solution and thankyou for reading, i hope this helps :D
Mar 22, 2011 | Sony PlayStation Portable (PSP) Console
how do you turn on closed captioning?
Using your remote:
1. Press the MENU button to open up the menu.
2. Press left or right until you reach the SETUP sub-menu.
3. Press UP or DOWN until you reach the CLOSED CAPTION option.
4. Press ENTER or RIGHT.
5. Press UP or DOWN until you reach the CC MODE option.
6. Press left or right to select ON
Hope this helps !
Mar 12, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
how to set time for aquastar N0 4095
When looking at the face, you have 4 pushers. Top left is for regatta function countdown. Top right is regatta function start-stop-reset. Bottom left is Hours-Minutes and Nite Lite. Bottom right is regatta function "catch up". Assuming that you want to set Hours and Minutes, press and hold the bottom left for 3 seconds...Hours will start blinking, press the pusher successively until the desired hour is reached. Then wait until it stops blinking. To set minutes, press and hold for 3 seconds, the hours will again begin to blink, then release and re-press for an additional 3 seconds and the minutes will blink, Then press successively until desired minutes have been reached. Stop pressing and wait until the blinking has stopped. Once it has stopped blinking your time has been successfully registered. Good Luck. Hope this helps!
Nov 02, 2009 | Watches
How dp you alter the time of the hands
  1. Press the Bottom Left side button until you reach time keeping mode.
  2. Press the Bottom Left side button 6 times to reach hand setting mode.
  3. Hold down the Top Left side button until the digital time starts to flash.
  4. Press the Bottom Right side button to advance the analog time by 20 seconds; Holding the button down will advance the time faster. Pressing both of the Right side buttons will lock the time into advancing quickly without holding buttons down; this will continue until you press a button or the clock advances 12 hours.
  5. Press the Top Left side button to exit the settings screen.
  6. Press the Bottom Left side button to return to timekeeping mode.
Mar 12, 2009 | Casio Watches
Freezes?
try this as it is a wide spead problem with lots of ps3s
Please run through the following, go through in order.
1) Delete the game's install data. This is done via the PS3 options. Scroll along the cross media bar until you reach the 'Game' tab, now scroll up / down the list until you reach the 'Game Data Utility' Enter this and locate the (GTA IV ) option or the game thats freezing option. Highlight this and press triangle once, from the menu select Delete. This will delete the game's install information.
2) Delete the game's save files. To delete any save files you will need to do the following. Scroll along the cross media bar until you reach the 'Game' tab, now scroll up / down the list until you reach the 'Save Data Utility' Enter this and locate the GTA IV / other game name option. Highlight this and press triangle once, and from the context menu select Delete.
3) Disable your Internet connectivity for the PS3. To do this scroll along the cross media bar until you reach the 'Settings' tab, now scroll up / down the list until you reach the 'Network Settings'. Now scroll down to the Internet connection option and press x, now select the disable option. Once this has been done unplug the ethernet cable if you are connecting to the Internet if using this.
4) Disable the console's information board. To do this scroll along the cross media bar until you reach the 'Network' tab, now scroll up / down the list until you reach the 'Information Board', highlight this and press triangle. From the menu select 'Do not display' Press X to confirm this.
5) Disable Media Server functionality. Scroll to Settings, now scroll up / down to 'Network Settings' select Media Server connection. Once this has been done press triangle and change the option Disabled.
6) Delete all of the system's Internet cache. To do this scroll along the cross media bar until you reach the 'Network' tab, now scroll up / down the list until you reach the 'Internet Browser', highlight this and press X. Once you browser opens press the triangle button once, from the new menu highlight the 'Tools' option and press X. Scroll down the menu until you reach 'Delete Cookies' and press X. Confirm the files deletion. Repeat this for 'Delete Cache'.
7 ) Turn off the PS3 screen saver. Use the cross media bar to scroll to 'Settings', select 'Display Settings'. Now highlight 'Screensaver' and set this to 'Do not use'.
8 ) Once this has been done, manually restart you PS3 by holding down the power button for 5 seconds it will beep once and then shut down. Release the power button and re-press it and hold for about 5 seconds. The system will then boot and reset all display settings. You will be prompted to reset your display settings to how you require them.
9) Once restarted please try the game again, you will be prompted to reinstall.
Once the game has started please turn off the following features:
1) The game's auto-save. Press Start, Game, and locate the Auto-save option. Turn this off.
2) Turn off the game's flicker filter. Press Start, Display and locate the Flicker Filter option. Turn this off.
3) Turn off the controller vibration feature. Press Start, Controls and locate the vibration option. Turn this off.
if this fails then you`ll need to call sony and i believe they charge for a fix...
Sep 26, 2008 | Sony Playstation 3 (PS3) Console
1,029 people viewed this tip
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
