Tip & How-To about Plumbing
Caulking - Finishing Tools
Caulking a Seam and/or Joint With Application Tools
There are many different tools on the market, but they all have the same principle in common - to help create a nice clean seam. There are only two real differences: push or pull. The type you pull, or back-drag, incorporates all the same tips as the push variety, so this article is written for the push tools.
Push tool application of silicone/acrylics caulking. Firstly, if you're like me, you will have a fair bit more silicone/acrylic then the paddle will hold. Every time you remove/re-apply the tool you will get "ripples" in the surface. Here are a few tricks I've learned along the way.
  • Rags: Mandatory - everyone knows this but most never have enough on hand. The trick is to always have a clean section to use when you need it. Folding the rag only works for so long. A roll of shop towels is handy to have on hand.
  • Soap and Water: A margarine container (or similar) half full of water (use warm/hot) and then a moderate squirt of dish detergent. The goal is a solution, not bubbles. Dip your tool often, this will make it easier to clean/use, and does not affect the material.
  • Clean and/or wipe the tool regularly. Material that sits for too long begins to cure, or skin over, and will be noticed in your finished product.
  • When using a push style tool, do manageable areas and back-drag. Once you've applied and cleaned one seam for instance, clean and dip the tool, then drag the profile backwards along the seam. This will smooth out any "ripples that have occurred.
  • Try to avoid back-dragging into old work (referring to the work you did earlier that day). This will prevent the skin of the material from rippling. Always try to back-drag from the edge of the old into the recent - as from the corner.
  • Finally, don't be afraid to use masking tape. Some people think that the use of tape is wrong, or the sign of an amateur. In truth, you're not trying to impress with how you do the job, but rather with the look of the job itself. Careful application, trimming, and handling of tape can make a job go very smooth. There will be times when the edge of the silicone/acrylic smears out really thin and much further then you anticipate. Having a taped edge you can remove will save on the cleaning.
Just remember one other important fact regarding silicone/acrylic... it will travel to where you don't want it seemingly on it's own. But a steady hand and using a few good tips will produce a finished product that will be pleasing to the eye as well as functional.
Richard C
Plumbing Logo
Water is flooding on both side floors.also in trunk and front floors
front or rear window leaking, poor, faulty caulking joint on seam of panels under wiper cowl, poor or damaged weather stripping.
sunroof leaking or plugged drain holes.
press the helpful button
How To Find Water Leaks in Your Vehicle EricTheCarGuy
Jan 23, 2016 | Cars & Trucks
broken granite sink
Sir and Madam,
Without a word this You Tube self help video says it all. The techniques and application can be diversified. Cheap Easy and dirty fix for cracked granite countertop . Best granite repair ever Best Granite repair ever . When you arrive in this area. There are several other how to videos at your fingertips. So lets get going. Fare well.
Oct 26, 2013 | Adhesives, Coatings & Sealants
How to put tape and putty on drywall
The TapeBuddy drywall taping tool is the answer to your taping problem. A one step drywall tape and joint compound application tool that makes taping easy. It's lightweight, easy to assemble and applies an even amount of joint compound directly to the joint tape. It even applies more compound to the tape center where more compound is needed. Just load with paper or Fibafuse tape and joint compound, pull out the coated tape, cut, apply to the seam and embed. There is no need to pre-mud drywall joints or carry around heavy tools. Taping walls, corners and ceilings is fast with no mess. TapeBuddy is a great DIY tool that will give you professional results. It is easy-to-use and the perfect tool for any drywall taping project.
The tool comes with easy-to-understand How To information on taping drywall. There is a how to manual on their website.
Jun 10, 2013 | Drywall
iam in the middle of a design project of a caulking gun, rather than jamming what are other problems which are common about caulking guns in general? thanks
you can leave them down without releasing the pressure and discover when you return that you have a great big mess to clean up...i hope this helps
Dec 09, 2008 | Grip On Tools Grip Heavy Duty Caulking Gun
498 people viewed this tip
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
