Tip & How-To about Home Security
Pressure mat alarm
Home Security Logo
how do i install applications
  1. Click Start where it says Add / Remove Applications.
  2. Type your password, if prompted, and click OK.
  3. In the Device Application Selection screen, click Browse. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  4. Once the application is in the Device Application Selection list, verify it is selected, and click Next.
  5. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
If you are using BlackBerry Desktop Manager version 4.0 to 4.3then you need to follow this steps:
  1. Connect the BlackBerry smartphone to the computer.
  2. In BlackBerry Desktop Manager, open the application loader tool.
  3. In the Application Loader Wizard, click Next.
  4. Type your password, if prompted, and click Next.
  5. In the Handheld Application Selection screen, click Add. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Handheld Application Selection list, verify it is selected, and click Next.
  7. On the Completing the Application Loader screen, verify the software to install is listed under Applications to be Installed or Updated, and click Finish.
  8. Once the application is installed on the BlackBerry smartphone, click Close in the Application Loader Wizard.
Jul 26, 2012 | Samsung C3050 Cell Phone
My storm 9500 can't download any software I have tried several times keep on denying.
Add, update, or delete applications on your device
You can add, update, or delete applications on your BlackBerry® device using the Applications screen in the BlackBerry® Desktop Software.
When you connect your device to your computer, your device is scanned and the applications are listed in the Applications pane.
1. Connect your device to your computer.
2. In the BlackBerry Desktop Software, click Applications.
3. When your device applications are listed, do any of the following:
• To update an application, click the + icon beside the name of the application.
• To delete an application, click the x icon beside the name of the application.
• To install an application file (.alx) that is saved on your computer, click Import files to browse to it.
4. In the Application Summary pane, review your changes.
5. Click Apply.
Dec 03, 2010 | 123Renamer Quick Flash Player
how to unblock sites
Blocking an application means it will not be able to access any information about you or send you any application requests. To prevent a specific application from accessing any of your information, simply click the block application link beneath any application request you received.
Alternatively, you can block an application by going to its Profile Page. To get to that page, follow these steps:
  1. Enter the application's name in Search.
  2. Scroll down and click to see more results. (Do not click on the application's "Game" result - this will take you to the application's Canvas Page rather than its Profile Page.)
  3. You should be able to locate the application that you're looking for under Applications. Click the "View Application" to the right of the search result to view the application's Profile Page.
  4. Click on "Block Application" beneath the application's picture.
You can see all your blocked applications on the "Block Lists" page under "Blocked Applications." If you want to remove any applications from this list, click "Unblock." Keep in mind that you will not see the "Blocked Applications" section if you have not blocked any applications. You will also need to grant the application permissions again if you would like to re-add it to your profile.
Nov 04, 2010 | AT&T Facebook Apps
how to install an application for my blacberry cellphone
If you would liketoinstall application using the application loader tool in the Blackberry Desktop Manager.
You should verify that the application to be installed on the BlackBerry smartphone is saved to the computer before completing the following steps.
If you are using BlackBerry Desktop Manager version 4.5 to 5.0 then you need to follow this steps:
  2. In BlackBerry Desktop Manager, click Application Loader.
  3. Click Start where it says Add / Remove Applications.
  4. Type your password, if prompted, and click OK.
  5. In the Device Application Selection screen, click Browse. Go to the directory of the application you want to add, select the <application>.alx file, and click Open.
  6. Once the application is in the Device Application Selection list, verify it is selected, and click Next.
Hope I helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 02, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
2,323 people viewed this tip
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
