Tip & How-To about Dryers
Gas dryer no heat issue
This procedure and the videos will help you with 90% of all no heat issues in a gas dryer. But first we must first understand what needs to take place and in what order for the dryer to heat.
The dryer door must be closed and the door switch made.The dryer will not start until the switch signals that the door is closed.
A motor turns the clothes dryer drum and also turns a fan called a blower.
A gas dryer uses a burner assy. (see picture below) which has two solenoids/coils,a heat sensor and a igniter. Once the sensor acknloedges the heat from the igniter (it must reach a certain temp,safety factor) the sensor signals the coils to open up the gas valve which in turn is now ignited by the ignitor.
The dryer has thermostats that control the temperature in the unit. The unit acts almost exactly like your furnace does. When it gets below a certain temp the igniter turns on and when the temperature reaches the high limit the heat is turned off.
Those are the basics of how a dryer works.
The videos below will contain information that will allow you to check your dryers
No heat issue when the dryer/vent is clean (always do this first!)
Pull the dryer away from the wall. Disconnect the vent from the dryer. Turn the dryer on. If the dryer heats then you know your dryer vent is blocked and needs to be cleaned.If the vent is not blocked proceed to the video procedure below. When the dryer is taken apart look for blockage in the vent tube,wheel blower. Take this opportunity to clean your dryer completely.
A dirty clogged dryer is a fire hazard!
Just click on the links that pertain to your dryer type.
Rule of thumb for gas dryers...If the dryer turns but never produces heat then check the fuse.If the drum turns and you get intermittent heat,ignitor comes on but goes off without flame coming on or "my dryer takes longer to dry my clothes then check the gas valve coils first.
The first video is how to use and read your volt meter.This meter can be used for all appliance and electrical repairs in your home. It takes out all of the guess work on repairs. You can purchase one at your local hardware or lowes/homedepot for between $8.00 and $12.00
How to use a volt meter.Click on the link http://www.youtube.com/watch?v=nddAA5IAUik
Use these settings when checking ohms on the gas valve coils
This video will show you how to take apart your dryer if the lint trap is on top of your dryer,click on the link http://www.youtube.com/watch?v=xGIG8Wo5-N4
This video will show you how to take apart your dryer if the lint trap is inside of your door. Click the link http://www.youtube.com/watch?v=2bVoelV7M7Y
How to take apart a Whirlpool duet Kenmore dryer control panel on front.Click on the linkhttp://www.youtube.com/watch?v=APlWrIcP94g
This video will show you how to troubleshoot a no heat issue in a gas dryer . Click on the link http://www.youtube.com/watch?v=Q8j6fQM3P34
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the linkhttp://www.repairclinic.com/Dryer-Belt-Diagrams
Please consider giving this procedure a four thumbs up!
Using FixYa and this procedure has saved you a minimum of $125.00!
Thank you for using Fixya!
Dryers Logo
electrolux dryer won't heat
a gas dryer has a ignighter that may have burned out. a $40 part
May 12, 2014 | Electrolux Dryers
My Kenmore series 90 Gas dryer doesn't heat up.
This dryer is what I like to call a 4 wheel drive model. Because it has wheels on the front as well as the back. To access the gas assembly you pop open the bottom panel. Strat the dryer and observe the gas assembly. You should hear a click and then the ignitor should glow. Next the flame sensor should trip and cause the ignitor to shut down. The gas will now be allowed to come out and fire off a blast.I have 2 home videos. on shows the operation and replacement of the coils. The other is of an electric model but shows how to put the dryer together.
Sep 21, 2012 | Kenmore 73052 Gas Dryer
Kenmore 90 Series dryer will not heat up.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 02, 2011 | Kenmore Dryers
Stopped heating while drying. Everything else ok, just no heat.
suedietze, this video with the link is very helpful and easy to understand. If you have any further questions, I would be happy to help you out. http://applianceassistant.com/videos/appliance_repair/whirlpool_dryer/gas_dryer_heating_problems.php
thanks,
Mike
Jul 19, 2011 | LG DLG5988 Stainless Steel Gas Dryer
Kenmore 90 Plus Series Gas Dryer that will not heat
It could be several other things thermal fuse, thermal cut out, hi limit thermostat, dryer coils, heat sensor,or igniter. All of these parts are inexpensive and easy to test and replace.There is a video at t http://appliancehelponline.com/gdryertroublevideo.html his will walk you thru the troubleshooting of these components. It may be a different model but the troubleshooting will be the same.You can also enter your model # for diagrams and illustrations. All parts come with installation instructions. Not all models are available. If you need help disassembling your machine there are videos of this also for most styles.
Jul 01, 2010 | Dryers
1,858 people viewed this tip
Top Dryers Experts
