Tip & How-To about Mozilla Firefox
How to change where Firefox saves downloaded files
Firefox by default saves anything that you download -- music, movies, documents, etc. -- to a specific Downloads folder. However, many users aren't aware of where this folder is, and they don't want to have to hunt it down every time to find their downloads.
By following the steps below, you can change the location where Firefox saves your downloads. You can have them sent to your desktop, a network folder, a thumb drive, or anywhere else that is accessible from your computer.
To change Firefox's download location:
1. Open Firefox.
2. On the menu bar across the top, click Tools.
3. Select Options from the drop down menu.
4. If the General tab at the top of the window is not highlighted, select it now.
5. Under the Downloads heading, after "Save files to," click the Browse button.
6. Choose a folder or location for Firefox to save your downloaded files to. You can create a new folder by highlighting the location where you want the folder to be and clicking the Make New Folder button in the lower left corner of the window.
7. Once you've selected the folder that you want and it's highlighted, click OK to close the Browse window.
8. If you would rather have Firefox prompt you where to save files every time you download something, click the circle next to "Always ask me where to save files." (This option is helpful if you want to save different kinds of downloads to different locations.)
9. Click OK once you are done to close the window and apply the change.
Mozilla Firefox Logo
How to move/copy user files to external hard disc (wall or usb powered) so that productivity applications default-save to the external hard disc (virtual drive) foldervia the serial bus rather than to
The answer is simple. Where files are saved by default is determined by the options you set in the software application. For example in Word, go into "File" , choose options and look for "save" on the left side. Then navigate to the drive and folder where you want your docs saved to, and make it the default. Same goes for Excel, and other apps
Oct 29, 2014 | Computers & Internet
Do you have a phone number for help in installing?
You need to rephrase your question. It's not clear what you are trying to do. Are you trying to watch a movie?. Or install a program or ?. Firefox is a web browser - I don't understand what you mean by "install a DVD for watching"... and why you would use Firefox to do this.
Oct 03, 2014 | Apple MacBook Air
i have downloaded a document in word, but dont seem able to save it onto my desktop.
1. if you have downloaded it via firefox the try the menubar Tools>Downloads then you can see all the downloads that you have done.
2. if you haven't shown the path to where the file has to be downloaded then it will by default download into the libraries where it has m documents, music, pictures etc..
Libraries\Documents
Libraries\music so on
3. Easiest option to find it out would be to search the document on your computer, which would bring it up for you if it is downloaded properly.
please rate it. thanks
Dec 27, 2010 | Computers & Internet
I want to set up my computer so that when I download anything, the computer will ask where I want to put the file. I have Windows Vista and if I want to put a mp4 on my desktop how would I set the computer up so it would ask me where I want the file? Right now when I download I have to search the computer to see where it's at.
Hi!
For the Mozilla Firefox browser, the setting is under Tools, Options, and select the Main tab. Under downloads, check "Always ask me where to save files".
Can you give me the name of the browser you are currently using now?
Nov 08, 2009 | Computers & Internet
Downloading using vista
I've found a couple of solutions, some might not be exactly what your looking for. EDIT: Soultion #2 should be your answer...
Solution #1 - Change the Documents Folder Template
  1. Click the 'Start' pearl (button)
  2. Under your name and icon, you should see the 'Documents' option.
  3. Right click 'Documents' and then select properties.
  4. The window should pop up and read 'Documents Properties'
  5. Click the 'Customize' Tab
******* Soultion #2
  1. Go into your documents folder.
  2. Off to the left side you should see the 'folders' section
  3. Under 'Desktop' you should see the folder with the windows account username. Go into that folder.
  4. Under the the folder you should see all of the default Vista folders, EX: Contacts, Deskop, Documents, etc.
  5. You can right click each folder and select properties, then under the 'Location' tab you can select the location of all of the files, and such where you want them to be.
Hopefully this helps you out, my directions could have been a bit rough if you have any problems please reply to the post!
Mar 20, 2009 | Microsoft Windows Vista Home Premium with...
620 people viewed this tip
Top Mozilla Computers & Internet Experts
k24674
Alun Cox
Are you a Mozilla Computer and Internet Expert? Answer questions, earn points and help others
