Tip & How-To about Cell Phones
Repairing phone that falls inside water or liquid
1.Unscrew the phone 2.Remove the panel 3.Wash the panel with original methylated spirit and a tooth brush 4.sundry for about one hour 5.couple the phone back 6.the phone must work
Cell Phones Logo
dropped in toilet
you need to get the phone fully dried for it to work well again.
Remove the battery and clean it very well. After that, get a phone screw driver, unscrew all the phone screws, remove the phone cover in order to gain access to the phone panel. Gently remove/detach the screen from the phone board.
Get a methylated spirit and a soft tooth brush, dip the tooth brush into the spirit and use the brush to clean the phone board. Wash/brush every part of the board with the spirit.
After that, dry the board under an electric bulb or under sunlight. Allow it to dry very well. Let the board get hot. Then leave the board for 5mins or more to cool.
After that, couple back the phone, fix in the battery and try again. Then phone will definitely power on.
Good luck.
Jan 04, 2012 | Cell Phones
my phone is wet!!!
you need to get the phone fully dried for it to work well again perfectly.
Regards.
Apr 29, 2011 | Cell Phones
I got my SAMSUNG GT-S5230 soaked in water. What should I do?
remove the battery and unscrew.then get methylated spirit to wash the panel using toothbrush.now sundry for hours.couple it back your phone will be ok
Mar 18, 2011 | Samsung Star GT-S5233 Cell Phone
i have a panasonic black and white handset and the problem with the mobile it say insert sim even the sim is inserted. so please suggest what is the fault of the mobile... Thank you...
unscrew the phone. get methylated spirit,use it to wash the phone panel using tooth brush.then sundry the panel for about 1 hour.screw the phone back.then it will work
Feb 04, 2011 | Cell Phones
158 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
