Tip & How-To about Audio Players & Recorders
SHURE E3g EARPHONE PROBLEM
IF YOU HAVE THE SAME PROBLEM WHAT I HAD WITH MY 3 YEAR OLD SURE E3g EARPHONE THAT ONE SIDE IS NOT LAUD ENOUGH......
I DID TRY ALL THE CLEANING WITH THE PROVIDED TOOL BUT ALL DID NOT HELP.
I DID USE A KNIFE AND DID SLOWELY FOLLOW THE GROVE ARROUND THE TIP OF MY BAD EARPHONE. AFTER A FEW MIN. WORKING WITH MY KNIFE IN THIS GROVE I DID FEEL THAT THE EARPHONE WILL COME APART. THE TIP HAS NO CONNECTIONS (ELECTRICAL SPEAKER WIRE CONNECTIONS) NOTHING IT IS JUST THE EARPHONE PLASTIC TIP. AFTER I HAD THE TIP IN MY HAND I USED A NEEDLE AND I GOT A LOT OLD EAR WAX OUT AND MY EARPHONE IS VERY LOAD AGAIN. NOW CLEAN BOTH SIDES AND PRESS THE TIP BACK ON. IF YOU FEEL BETTER USE A DROP SUPER GLUE TO BE SURE IT WILL NOT COME APART AGAIN AND STUCK IN YOUR EAR. I DID NOT USE ANY GLUE.
I HOPE THIS DID HELP YOU TO CONTINUE TO LISTEN YOUR MUSIC WITH YOUR SURE E3g EARPHONE
12 year old GE ref side by side both sides warm
has cleaning the condenser coils helped out? does the condenser have a fan? if so when the compressor is running it should be running also. is the compressor hot to touch?
May 20, 2014 | Refrigerators
On the left side when you press the toast button the tray does not lower.Is this a common problem.The toaster is over 1 year old.
Try cleaning and scraping out any debris in the toaster. Mine had several places where I had to scrape it out with a screw driver. Make sure you do it outside and unplugged. The debris was actually keepeing the carrier from going down.
Jan 30, 2011 | Breville BTA840XL 4-Slice Toaster
DOES SAMSUNG REFRIGERATOR'S FAN MAKE LAUD NOIS?, BECAUSE I HEAR ONCE A WHILE LAUD RUNNING NOISE. I CLEANED AND REMOVED THE DUST FROM THE ENGINE. THANKS FOR HELP FARO
it may make due to manufactureres fault or may be a fluctuation problems ask mechanic to dismental it do not try ur self
Dec 13, 2010 | Refrigerators
Shure E3G
See the following FAQ on this topic:
http://shure.custhelp.com/cgi-bin/shure.cfg/php/enduser/std_adp.php?p_faqid=3407
Jul 10, 2010 | Shure E3g Consumer Headphones
Freezer is cold but not keeping icecream frozen.
If, the fresh food section is 34- 38 degrees, then the freezer should be cold enough to keep ice cream solid. All of the cooling capability comes from the freezer section. I, personally, would not waste time or money on a ten year old box. Ten years ago it cost $1000, so, the outlay is $100 per year. Dump the old refrigerator and get a new one.
Aug 27, 2009 | Refrigerators
1,802 people viewed this tip
 Grubhead
Grubhead
