Tip & How-To about Ricoh Aficio SP C811DN Laser Printer
How to change the IP address on a Ricoh Aficio C811 printer
With the use of a DHCP (Dynamic Host Configuration Protocol) server, you can automate the administration of IP addresses for printers. However, you may want your printer to have a static IP address. To set up a static IP address on a Ricoh Aficio C811 color printer, follow the steps below.
1. When the printer is powered on and ready, press the Menu button.
2. Using the up or down arrows, scroll down through the menu to Host Interface and press OK.
3. Scroll down to Network and press OK.
4. Machine IPv4 Address is the first option on the network menu; click OK when it is highlighted.
5. You will see two options -- Auto-Obtain (DHCP) and Specify, and below them are three tabs -- IP Add., Subnet M, and Gateway. Scroll down so that Specify is highlighted, and then press the arrow button below the left-most tab (IP Add.).
6. Using the up and down arrows to change the numeric value, enter the IP address you want to use for the printer. Use the side arrows to go to the next part of the address once you've entered the value for the current octet.
7. Once you've entered the complete IP address, press OK. (If you want to cancel out without saving the new address, press Escape instead.)
8. If you need to specify a subnet mask and gateway address, you can enter those values in the same way, by selecting each of the corresponding tabs on the IPv4 menu (Subnet M and Gateway, respectively).
9. After you've entered all of the information and saved each address, make sure Specify is highlighted and press OK. You should see "Programmed" displayed on the screen.
10. Turn the machine off and then back on to apply the changes and reset the network connection.
Ricoh Aficio SP C811DN Laser Printer Logo
find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
my ip adress says unavailable
Sounds like the computer you're trying to connect to your wi-fi router is set up with a static IP address that is being reserved by your router for DHCP. To resolve, make sure your router has "DHCP" (dynamic host configuration protocol) turned on. Make sure the computer you're trying to connect to your router is set up to allow the DHCP server in your router to set the computer's IP address and DNS server address. You can find instructions to enable DHCP in your router's user manual or by searching online. You can find instructions for setting your computer's wireless adapter to allow the DHCP server in your router to set the computer's IP and DNS addresses here:
http://www2.wolfson.cam.ac.uk/files/IT/Settings_for_DHCP_for_Windows.pdf
Jan 07, 2014 | Computers & Internet
How do I change my WD5000G032-001 external hard drive's IP address?
Very few external disk-drives _have_ an IP-address (the Apple Time-Machine is the exception). For those drives that do,
they obtain their IP-address automatically, by sending a 'request' out through their network-connection. A DHCP ('Dynamic Host Configuration Protocol') server on the network sends an IP-address to it. Most 'home' routers (wired or wireless) include the DHCP-server functionality.
So, the only way to change the IP-address is to configure the DHCP-server to always assign the desired IP-address whenever that specific device sends a 'request' for an IP-address.
Oct 06, 2010 | Western Digital 500GB My Book World...
What is BOOTP/DHCP?
BOOTP stands for Bootstrap Protocol. DHCP stands for Dynamic Host Configuration Protocol. Both are mechanisms to dynamically assign an IP address for a TCP/IP client by the server. In this case, the Prestige 310 Internet Access Sharing Router is a BOOTP/DHCP server. Win95 and WinNT clients use DHCP to request an internal IP address, while WFW and WinSock clients use BOOTP. TCP/IP clients may specify their own IP or utilize BOOTP/DHCP to request an IP address.
Feb 19, 2006 | Zyxel Prestige 310 (AM406100) Router
5,048 people viewed this tip
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
