Tip & How-To about Computers & Internet
Removing IE 8
If you have problems with Internet Explorer 8, you might want to try Compatibility View or our guided help to see whether you can fix the problem. However, if you just want to uninstall, or remove, Internet Explorer 8, this article helps you do that.
When you remove Internet Explorer 8, your earlier version of Internet Explorer is restored with your customizations (such as add-ins, Favorites, and your home page).
Resolution:
To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator
Important: You cannot uninstall Internet Explorer 8 if it is set as not removable. This occurs if you install Internet Explorer 8 before you install Service Pack 3 (SP3) for Windows XP. If this scenario applies to you, then you must uninstall SP3 before you can uninstall Internet Explorer 8. For more information about this issue, click the following article number to view the article in the Microsoft Knowledge Base:
950719 You cannot uninstall Internet Explorer 7 or Internet Explorer 8 after you install Windows XP Service Pack 3
To uninstall Internet Explorer 8, follow the instructions for your version of Windows. To follow these steps, you must be logged on to Windows as an administrator.
Steps for Windows 7
To uninstall Internet Explorer 8, follow these steps:
1. Close all programs.
2. Click StartCollapse this imageExpand this image, and then click Control Panel.
3. Click Programs and Feature.
4. In the tasks pane, click Turn Windows features on or off.
5. In the list of windows features, clear the check box next to Internet Explorer 8.
6. You receive a warning message in a pop-up window. Click Yes.
Internet Explorer 8 will now be uninstalled. The system will restart after the installation.
Steps for Windows Vista or for Windows Server 2008
loadTOCNode(3, 'resolution'); To uninstall Internet Explorer 8, follow these steps:
  2. Click Start, and then click Control Panel.
  3. Click Uninstall a Program under the Programs category
  4. In the Tasks pane, click View installed updates.
  5. In the list of installed updates, double-click Windows Internet Explorer 8.
    Note: If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative steps for Windows Vista or for Windows Server 2008.
  6. In the Uninstall an update dialog box, click Yes.
    Note: If you are prompted for an administrator password or for confirmation, type the password, or click Continue.
  7. Follow the instructions to uninstall Internet Explorer 8.
  8. When the uninstall program is finished, restart your computer.
Steps for Windows XP or for Windows Server 2003
  3. Click Add or Remove Programs.
  4. In the list of currently installed programs, click Windows Internet Explorer 8, and then click Remove.
    Note: If Windows Internet Explorer 8 does not appear in the list of installed updates, try the alternative steps for Windows XP or for Windows Server 2003.
  5. Follow the instructions to uninstall Internet Explorer 8.
  6. When the uninstall program is finished, restart your computer.
Alternative steps
Alternative steps for Windows Vista or for Windows Server 2008
loadTOCNode(3, 'moreinformation'); To uninstall Internet Explorer 8, follow these steps:
  1. Carefully select and then copy the following command:
    FORFILES /P %WINDIR%\servicing\Packages /M Microsoft-Windows-InternetExplorer-8*.mum /c "cmd /c echo Uninstalling package @fname && start /w pkgmgr /up:@fname /norestart"
  2. Click Start, and then type Cmd.exe in the Start Search box.
  3. In the list of programs, right-click Cmd.exe, and then click Run as administrator.
  • Right-click inside the Administrator: Command Prompt window, and then click Paste to paste the command that you copied in step 1.
  • Press ENTER to uninstall Internet Explorer 8.
  • When the uninstall program is finished, restart your computer.
  • Alternative steps for Windows XP or for Windows Server 2003
      %windir%\ie8\spuninst\spuninst.exe
    2. Click Start, and then click Run.
    3. In the Open box, type Cmd.exe, and then press ENTER.
    4. Right-click inside the Cmd.exe window, and then click Paste to paste the command that you copied in step 1.
    5. Press ENTER to uninstall Internet Explorer 8.
    7. More Information:
    8. After you uninstall Internet Explorer 8, you may notice Application event log errors after each reboot. To resolve this problem, delete the following Internet Explorer User Accelerators and Internet Explorer Machine Accelerators registry keys in HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon\GPExtensions:
    9. {7B849a69-220F-451E-B3FE-2CB811AF94AE} {CF7639F3-ABA2-41DB-97F2-81E2C5DBFC5D}
    10. The information in this article applies to:
    11. Windows Internet Explorer 8
    Computers & Internet Logo
    how do I change the compatibility mode on the PC to normal;
    you can change the compatibility view settings on internet explorer 8 by following the steps below:
    1. open internet explorer
    2. go to "tools"
    3. go to "compatibility view settings"
    4. the websites that have been added to compatibility view list will be displayed in the box under "websites you've added to compatibility view". you can remove them by using the "remove" option besides the box.
    the following link can be helpful:
    http://windows.microsoft.com/en-us/internet-explorer/use-compatibility-view#ie=ie-8
    guruaid.com
    Jan 20, 2015 | Microsoft Windows Internet Explorer 8 for...
    Facebook page is cut off.... I cant see the lower parts of applications running on FB. Had the same problem a couple of months back. Applicationteam Westwars has solved it - they have a redirecting page now......
    Good Day Carsten!
    This solution might fix your problem permanently.
    If you are currently using an Internet Explorer version 8 or 9, try to disable all compatibility view settings.This versions of Internet Explorer runs compatibility view.
    To disable, go to Tools menu, scroll down and unchecked "Compatibility View" and "All Compatibility View" settings.
    If this will not fix your problem, try using a different internet browser like Mozilla Firefox or Google Chrome. These works better for Facebook site.
    To download, go to http://www.mozilla.com/en-US/firefox/new/ - for Mozilla Firefox or http://www.google.com/chrome/intl/en/make/download.html?brand=CHKZ&hl=en - for Google Chrome.
    Please do not forget to consider downloading the latest Adobe Flash Player. This will help your system runs the games and graphics of Facebook.
    To download Adobe Flash Player, go to http://get.adobe.com/flashplayer/
    You can comeback later to give me a four thumbs up rating if this solution fix your problem.
    Jun 01, 2011 | Facebook Social Network
    How to Correct the Error KB927917
    There are a couple of things you can try to fix this. I think you must likely will just need to run IE8 with 'compatibility view' enabled (see below).
    Method 1
    I would suggest you to run the website in Compatibility mode and check whether you are able to access the website. Follow the steps mentioned below to turn Compatibility View on or off,
    a. Click the Compatibility View button that is present near the address bar, or add the website to the Compatibility list.
    Follow the steps mentioned below to add the website in compatibility list.
    a. Open Internet Explorer by clicking the Start button. In the search box, type Internet Explorer, and then, in the list of results, click Internet Explorer.
    b. Click the Tools button, and then click Compatibility View.
    For further reference follow the article mentioned below.
    Why don't some websites display correctly in Internet Explorer?
    http://windows.microsoft.com/en-US/windo...
    Method 2
    I would suggest you to Reset internet explorer and check, whether the issue persists. Follow the steps mentioned in the article given below.
    Reset Internet Explorer settings
    Hope one of these works!
    Feb 04, 2011 | Microsoft Internet Explorer 8
    im not getting a compete picture when my computor is on theinternet.
    To correct this issue, follow the methods that are described in this section in the order in which they are presented until the issue is resolved.
    These methods are designed for beginning to intermediate computer users. After each method, refresh Internet Explorer to check whether the problem is resolved. If the problem is not resolved, try the next method. Method 1: See whether pictures are available on another Web site loadTOCNode(3, 'resolution'); Sometimes the link to a picture on a Web site is broken, and that is why a picture is not being displayed. Visit another Web site to determine whether pictures are being displayed correctly on it. If they are being displayed correctly, then there is nothing wrong with Internet Explorer. Instead, the Web site that you are visiting might be broken.
    If you can view pictures on another Web site, you are finished. If you do not see any pictures or if you cannot determine whether the Web site that you are visiting is broken, try clearing your temporary Internet files by using method 2.
    Note If you use Internet Explorer 8, try Compatibility View. To do this, start Internet Explorer 8, click Compatibility View Settings on the Tools menu, and then add the Web site that you want to view by using Compatibility View. Method 2: Clear temporary Internet files loadTOCNode(3, 'resolution'); Clearing your temporary Internet files creates more space on your hard disk. If your hard disk is close to being full, this could affect your ability to view pictures on a Web site.
    To clear temporary Internet files, follow these steps:
    Internet Explorer 8
    1. Start Internet Explorer 8.
    2. On the Tools menu, click Internet Options.
    3. On the General tab, click Delete under Browsing History.
    4. In the Delete Browsing History dialog box, click to clear all of the check boxes except for the Temporary Internet Files check box, and then click Delete.
    5. Click OK to close the Internet Options dialog box.
    Internet Explorer 7
    1. Start Internet Explorer 7.
    2. On the Tools menu, click Delete Browsing History.
    3. In the Delete Browsing History dialog box, click Delete Files.
    4. Click OK to close the Internet Options dialog box.
    Internet Explorer 6 and earlier versions
    1. On the Tools menu, click Internet Options.
    2. On the General tab, click Delete Files under Temporary Internet files.
    3. Click to select the Delete all offline content check box, and then click OK.
    Check whether you can now see pictures. If you still cannot see pictures, try method 3. Method 3: Verify that the Show Pictures option has not been turned off loadTOCNode(3, 'resolution'); If the Show Pictures option in Internet Explorer is turned off, you cannot see pictures. To determine whether the Show Pictures option is turned off, follow these steps:
    2. Click the Advanced tab, and then verify that the Show Pictures check box is selected under Multimedia.
    3. Click OK.
    Determine whether you can now see pictures
    Please rate me if this solution works for you
    Thanks......Have a great time.
    Jul 13, 2010 | Gateway Essential 400 PC Desktop
    Problem with Internet Explorer 8 for sap Application
    Please do the following :-
    In IE 8, Click on Tools -> Compatibility View Settings -> Add the domain name you want to open. Also you can check 'Display all Websites in Compatibility View'. This should solve your issue.
    Mar 27, 2009 | Computers & Internet
    313 people viewed this tip
    David Payne
    David Payne
