Tip & How-To about Computers & Internet
Unregistering DLLs
Introduction:
What are DLL files?
DLLs are dynamically linked library files. DLL file contains a list of certain functions that can be used by various applications. Spool32.dll is a great example of how the things work: that file is used by various programs for print control within Windows 95 and Windows 98.
Why is it important to unregister malicious DLLs?
DLLs may contain information essential for a computer to function properly. Malicious programs may corrupt regular DLL files or they may install new DLLs instead of normal ones.
Deleting DLLs is a risky deal since it can affect computers performance and functionality of many applications. If a malicious DLL is somehow used by a regular application and the DLL file is removed, the application won't work normally even if the deleted DLL is not needed for a program to function. This is why you have to unregister DLLs before deleting them.
How to unregister malicious DLL files?
a) Open Command Prompt window
Click the "Start" button and select "Run" option. Type "cmd" into the "Open" field and click the "OK" button.
b) Unregister malicious DLL file
Type "regsvr32 /u filename.dll" into the Comand Prompt window and click "Enter". "Filename.dll" should be the name of DLL file you want to unregister
Computers & Internet Logo
error rundll32
at pc? more info? i think wrong section ^_^
What is rundll32.exe (rundll32.exe error)?
rundll32.exe (rundll32.exe error) Description: Rundll32.exe is a program which would have been on your pc since the day you purchased your pc. Always verify the exact disk location as many virus and spyware writers will attempt to fool you by using a similiar name or same name in a different location. This file is part of the Microsoft Windows operating system. Rundll32.exe will actually execute functions in DLLs. If you are deleting files on your computer as a spyware removal protection method, then note that this is a required system file. Note that rundll32.exe can also be running many different other DLL or EXE programs, so you may want to check the programs listed after it in your startup list also, as these may be executed by it. Rundll32.exeis considered safe and is not spyware, adware, or virus related and does not need to be removed.
rundll32.exe error: rundll32.exe error. Be sure to always double check your spelling if you are concerned about spyware, as often spyware will use a very similiar spelling of system processes or other common tasks. rundll32.exe error
Click here to remove rundll32.exe virus
remove rundll32.exe virus: Remove rundll32.exe virus. Remember that although many files are always in default file locations, some files can easily be moved to different locations or change names like many spyware, adware, or popup programs do. If you suspect you have spyware or adware, check to see if you see a similiar names stored elsewhere. It always helps to check your tasklist also to see what is currently running on your computer. You can always view the tasklist on your computer by pressing ctrl-alt-del to view your "task manager", and then click the "processes" tab. This will show you all tasks running on your computer. Dll files will NOT show on your computer tasklist, as dll files are actually part of other processes. You may see similiar program names running if spyware or adware is on your computer, for example, ati2evxx.exe may be slightly misspelled to keep you from finding it, or spyware and adware may be named very similiar to a system file. Make sure always check the location of tasks or processes if you are concerned.Remove rundll32.exe virus
rundll32.exe Common Path(s): This will be found in your windows\system32 folder. You will see it starting up programs like: RUNDLL32.EXE C:\WINNT\System32\NvCpl.dll,NvStartup
^_^
Apr 20, 2014 | Nokia Asha 201 Blue Unlocked Dual-Band GSM...
The ordinal 120 could not be located in the dynamic link library iertutil.dll
iertutil.dll is a dynamic link library used by Internet Explorer. Ordinal 120 refers to something inside the dynamic link library. These errors typically occur when the file is corrupt or there is a version mismatch (eg. IE 9 using iertutil.dll from IE 8). A reinstall of IE should fix this problem
Ericthecmh
Oct 05, 2011 | Microsoft Windows XP Professional for PC
Acer Aspire One Netbook D260A.Windows XP not booting. Message Reads Windows could not start because the following file is missing or corrupt. Windows Root System 32 Hal dll No recovery disc or USB recovery available. Step by step how to Fix? Help appreciated. Thanks
Sometimes you can get the needed .dll file online, and manually place it on that drive, of course in the correct directory.To do this, you need a functioning computer and you hook up the hard drive with the problem VIA USB. You can get USB Hard drive adapters from most retailers.
You may want to extract all data before you do anything, just in case. Have you been doing backups????
Usually, you reinstall the OS to resolve this issue, but without disks, not so easy to do.
Feb 03, 2011 | Computers & Internet
153 people viewed this tip
David Payne
David Payne
