Tip & How-To about Computers & Internet
Speeding up your Computer
Howto Speed up the Computer 1. WindowsDefragmenter utility: You can use this utility by using this path Start >Programs > Accessories > System tools > Disk defragmenter. This isbuilt-in utility in Windows operating systems and this will automaticallyanalyze the empty disk space on the hard disk and defragment and all scatteredfiles.
2. Shutdown Unnecessary programs: By using this path Start > Run >Msconfig > Startup, you can close all unwanted programs at the Windowsstartup and this will automatically increase the windows loading time and speedof the computer will also be increased.
Computers & Internet Logo
how to reset my computer
Start - > Programs - > Accessories - > System Tools - > System
Restore
There will be two option:-
- Restore my computer to an earlier time.
- Create a restore point.
Now what do you want? No.1 or No.2
Just click on it >Next and follow instruction, that's it.
But in this procedure you will loose your data or you have to take backup of your all data. So I would suggest you to download RegInOut its provides various features that make your PC maintenance job easier. It automates the difficult tasks and scanning through it is safe and tested on hundreds of thousands of PCs all over the world.
Following are the main benefits of using RegInOut:-
- Repair and clean registry errors crashes and freezes in applications and programs.
- Optimize and speed up internet through the internet optimizer feature.
- Clean up the backyard.
- System Cleanup Registry Cleaner
- Internet Optimizer feature Services Optimizer
- Defragmenter Startup Manager
Thanks
Nov 07, 2013 | Computers & Internet
how i improve my computer speed
THere are many available utilities software which helps you on improving computer speed.
My recommendation, is the one I am using called TuneUp Utilities 2011.
Norton has its own. THere are many, but I prefer the one I mentioned.
These programs will have a registry cleaner, hard disk defragmenter, it will give you many options to improve your system.
But if you are low on budget.
1. Do a hard disk defragmenter, included on system tools on windows start menu ---> accessories
2. Clear the startup programs on unnecessary programs. Do this by running MSCONFIG, and clear the startup programs you think you don't need.
3. Install more memory, you have to check which memory is compatible with your computer.
God Bless You!!!
Feb 14, 2011 | Computers & Internet
hi my computer runs real slow ive use mcafee to try to clean it but it seems to be still running slow
Click Start-> Run, type msconfig and click Ok. The System Configuration Utility will start. Now click on Startup tab. You will see a list of programs which starts automatically when Windows starts.
In that list, uncheck the program items, which you generally don't use. It will make your computer a little faster.
The above procedure can also be modified a little, that is uncheck all items under Startup tab, restart your computer.
Now check one item at a time, restart computer and test the speed of your computer. This way, you will find the programs, which are making the computer show. Remember to use a pen and paper to take a note about which items you are selecting or unselecting.
Please try one more thing:
Open Start-> Settings-> Control Panel-> System. Click on Advanced tab. Under Performance, click on Settings, click on Adjust for best performance, click Apply and Ok.
Then do this Click->Start->Programes->Accessories->System Tools->Disk Clean Up and select the C:Drive and clean it
Thanks
Mar 15, 2010 | Dell Dimension E521 (D10E16) PC Desktop
my computer is really slow. any suggestions?
You can do the following:
1. Perform a Disk Cleanup to delete all uneccessary files from your computer. Click Start button, All Programs, Accessories, System Tools, Disk Cleanup. Choose drive C: and check all the boxes and start cleanup by hitting Ok.
2. Do a virus scan. The computer might be compromised thus performing so slow. Here's an effective and free online scan: http://eset.com/onlinescan
3. Defrag your computer. Go to Start >> All Programs >> Accessories >> System Tools >> Disk Defragmenter. This is used to increase access speed by rearranging files stored in your computer.
4. Check for your computer's memory. If you have 2 memory sticks installed, one might have failed. Right click your My Computer and choose Properties. On the general tab, check if it still giving you the value of memory that you used to have on your computer.
Hope this helps.
Dec 18, 2009 | Dell Dimension 4600 PC Desktop
122 people viewed this tip
David Payne
David Payne
