Tip & How-To about Computers & Internet
Fix Your Computer Problem Windows
Computers & Internet Logo
MONITOR BLACK PC BEEPS AND BEEPS CONTINUOSLY
Beep codes are used by the BIOS during the POST to report certain initial system errors.
If you're hearing beep codes after you turn your computer on, it typically means that the system has encountered some kind of problem.
depending on the type of beep your motherboard makes you can get to know what your problem is. below are beep code links for various BIOS manufacturers. check yours.
http://pcsupport.about.com/od/fixtheproblem/tp/ami-beep-codes.htm
http://pcsupport.about.com/od/fixtheproblem/tp/award-beep-codes.htm
http://pcsupport.about.com/od/fixtheproblem/tp/phoenix-beep-codes.htm
Most likely you have a faulty ram, try to use a friends ram to see if that works. make sure that your friends ram is compatible with your computer.
Jan 24, 2014 | Sony VAIO Digital Studio PCV-RX660 PC...
boot mgr is misslng how do i fix this problem
You need to perform a Windows repair:
For XP:
http://pcsupport.about.com/od/operatingsystems/ss/instxprepair1.htm
Win 7:
http://pcsupport.about.com/od/toolsofthetrade/ss/windows-7-startup-repair.htm
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Mar 17, 2011 | Acer Computers & Internet
iam getting an error which says "Reload needed DLLs for HAL"
Try these: Do a system Restore: http://pcsupport.about.com/od/fixtheproblem/ht/systemrestorecp.htm < that will show you how
Restore hal.dll from XP CD (or w/e operating system you have) http://pcsupport.about.com/od/fixtheproblem/ht/restorehaldll.htm
Those are the ways that i typically fix the error. If they both fail, you probably need to reinstall your operating system.
Mar 01, 2011 | Dell Optiplex GX280 Intel Desktop PC -...
how can i reboot my computer
Hi xxx Krshna,
Just restart your PC and press the f8 key again and again Now can see the text windows >select last known good configuration If your PC will not boot , do it again,please restore your OS follow the steep. Restart>f8>save mode> > select the selected date (darken date )date >ok
If it will create the same problem please set the BIOS
restart>press del /F2 /F10 for enter to bios. To know more look
http://www.computerhope.com/issues/ch000235.htm
clear CMOS and restart >press del /F2 /F10 for enter to bios>set optimize default and F-10>yes.If want do in another way
http://pcsupport.about.com/od/fixtheproblem/a/biosaccess_pc.htm
http://pcsupport.about.com/od/fixtheproblem/ht/accessbios.htm
Hope it will help you.
Dec 03, 2010 | Computers & Internet
185 people viewed this tip
David Payne
David Payne
