Tip & How-To about Office Equipment & Supplies
Printer error codes
This site shows the error codes for many different printers.
And what the code means:
http://www.visualhawk.vcc.ro/canon_error_codes_en.html
Hope this will help.
What is responsible for system error e225
have listing of most common codes here:
system error e225 refer to bad connection or power failure to the scanner, sometime can be solved, please follow this procedure:
1. switch machine on and wait till fully initialize, while it is "alive" disconnect power cord
2. leave disconnected for 10min
3. if possible - connect to known working different power socket (directly to the wall socket! no extensions, no power boards!)
4. wait till fully initialized, check if error still display, if not - problem solved,
if still error is displayed, go to canon site (this is not us unit, select therefore your appropriate division, somewhere there find contact and ask them for firmware update:
canada:
http://www.canon.ca/inetCA/en/serviceDetail?m=load&id=5&sid=28&mid=0002200586&type=S
australia:
https://www.canon.com.au/about-canon/contact
europe:
http://www.canon-europe.com/For_Home/Product_Finder/Multifunctionals/Laser/i-SENSYS_MF4380DN/
hope this will help you find correct solution, do not forget to vote...
Jan 12, 2015 | Canon I-sensys MF4010 All-In-One Laser...
canon
CANON 6050, 6650, 8070, 8570 E020 black toner supply mechanism malfunction
Taken from: http://www.visualhawk.vcc.ro/canon_error_codes_en.html
You may want to consider buying a new printer, unless this one is worth a repair bill.
Jul 10, 2009 | Office Equipment & Supplies
E020-0181
I don't know about the color copiers but here is a list of error codes, and their likely problems.
Looks like you will have to ge t a tech to fix it.
Oct 23, 2007 | Canon CLC 1140 Copier
308 people viewed this tip
jasbo
jasbo
