Tip & How-To about Drills
Tough screws
If you are having a hard time getting a srew to go in, simply take the screw, put some soap on it, and then start to drive it in. It will take the muscle out of the work, save you time, and the need for a power tool.
Drills Logo
how to adj the crab on a poulan chainsaw
if the engine is in good shape..screw in both carb jets adjusting screws till they seat lightly, then back them out 1 1/2 turns, srew in the throttle adj screw a turn and start the motor,,warning if the chain is on make sure the blade isnt likely to touch anything when the engine starts as you will have to have the brake off to get started and adjusted. With the engine running, adjust the throttle srew until it is idling just above shutting off speed, then adjust the "L" low speed jet to get the best idling speed without srewing it in much, reset the throttle srew, then , while trying to accelerate suddenly each time, open the Low jet a little at a time until the machine accelerates smoothly without hesitation. Reset the throttle srew to a position that the chain stops running at idle and check again that the acceleration is without hesitation ( usually with "L" jet about 1/4 turn out more than best idling). The high "H" jet can now be set to give the best power while cutting a block of wood.
Jun 29, 2014 | Poulan Garden
how do I clean the insides of the dishwasher?
about the easyiest way to get rid of any smells or soap scum is goto home depot they sell a product there called AFFRESH they make two kinds one for front load washers which can also be used on top loader washers as well and another just for dishwashers simply put one of the tablets inside your dishwasher on the hotest cycle without any dishes and run the wash cycle and it removes all soap scum and any water smells as well if your looking to remove food or other items like that you would have to take off the top of the sump and clean out the chopper area usually 5 screws that hold on the upper sump screen most of the time they are star or torques drive headed screws if you have any further questions message me back Thanks again Rick
Jan 15, 2011 | Kenmore Dishwashers
remove the hard drive in a acer 1690 wlci laptop
on the bottem are one or 2 srews this wil release the cover for the hard disk if removed place thin schrewdriver and lift up on serws hole and the disk are also with srews hold on his place look out befor you buy a new one there are diferend syses for the hard disk one fits the other are larger in hight
i hope i helps you with the explanation for it
Mar 10, 2010 | Acer Notebook
Dead hard drive
it will be real silm like and it will be on the side where the cd player is not you may have to unsrew to srews and it should just slide out
Feb 14, 2010 | Audio Players & Recorders
hard drive caddy stuck
Try giving it a lift and then try to remove it.
Feb 05, 2009 | Dell Inspiron 2200 Notebook
995 people viewed this tip
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
